Question about Robert Yick Co. RanRYC168 Gas Kitchen Range
Creda c362e cooker
The main oven has stopped working, everything else works, all wire conecters are fine, where would i start to check for a breaker fuse, or could it be the elements in oven
0 characters
1 Points
Self cleaning mode
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 20, 2010 | Creda C362E Electric Kitchen Range
How do I get a manual on a Creda Concept Solarglo Cooker
When i turn on the kitchens rings,they turn on for 10 seconds and after turn off for half minute and this process continue to repeate again and again. The indicates of screen change allte time, and i dont know whats happen with the kooker.Please inform me what to do. Thtank you!
Apr 21, 2009 | Creda C362E Electric Kitchen Range
Creda grill will not switch to oven when i shut the door
Model Number TGF334BCWF Gas Stove.....When I turn the burner on the top front right my oven is coming on without me turning the on. What is going on?
Feb 21, 2009 | Creda C362E Electric Kitchen Range
I have a creda c362e double oven cooker and the main oven does not heat up at all the grill, top oven and hob all still work
Depends on how handy you are with a screwdriver as to whether you want to repair yourself, although it is really basic. First turn off at the wall and remove the shelves from the bottom oven. The rear wall of the oven is held in place by 4 screws and one light cover and the heater element is behind this. Unscrew at the top, unclip from the bottom and remove the wires attached to the back. Test with a circuit tester but does sound like its no longer working. Very easy to order off the net for around £10 if you search for c362e element. Refitting is just a reversal of this. If you are not confident with electrics or if its still under warranty... get out an engineer.
Sep 13, 2008 | Hotpoint Kitchen Ranges
Creda concept cooker oven stopped working fan still going light gone when cooker was on opened door and there was sparks comming from were the fan is and a bit of smoke then oven stopped its 5yrs old
circular element has gone. remove rear panel inside oven and element will be in sight. to replace, remove also back external panel and element is held in by two nuts usually. make a note of wiring before starting. element cost is about £30
Aug 31, 2008 | Kitchen Ranges
Creda concept halogen cooker -2nd hand
bad timer, or the elements are bad. or the breakers are all kicked. check the breakers and the gfci plugs for the kitchen, just as is below.
for the apartment problem, check the breakers in the breaker box, and turn off then back on. if still not working, check the kitchen plugs for a gfci plug (has a tiny push button in the middle, push to reset) being kicked.
Jul 16, 2008 | Creda C361E Electric Kitchen Range
Old Creda double oven keeps runing when switch off
sounds simple but look at the knob to see if it is cracked and hence not turning the shaft
Jun 22, 2008 | Creda C362E Electric Kitchen Range
Creda cooker not working properly
my creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Jan 23, 2008 | Creda C362E Electric Kitchen Range
Robert Yick Co. RanRYC168 Gas Kitchen Range Logo
Top Robert Yick Co. Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Are you a Robert Yick Co. Kitchen Range Expert? Answer questions, earn points and help others
