Question about Acer Aspire 3680 Laptop
Acer aspire 3680
My notebook keeps coming up with a bluescreen sayin there is a problem detected physical memory dump. the restarts. how can i fix thius
  • 1 more comment
  • beninardi May 13, 2009
    there s a stop msg on the blue screen but it only has numbers
    re: Joed 911
    when the error coes up it goes to a blue screen then gives technical reasons its has STOP the codes. what causes this and what can fx it
  • JDTec
    JDTec May 11, 2010
    Does it give your a numeric Stop error message?
    What actually cause the physical memory dump?
    • DLL error
    • RAM Hardware Problems
    • Memory allocation error
    • COM error
    • HIVE crash
  • 191 Answers
You need to do:
1) open the ram slots cover at back laptop, see two ram slots, take out rams and clean the pins use soft paper,then put them back
2) still blue screen, you need change another ram instead old one(or two), it should be same model on the ram lable.
hope help you to fix it
Posted on May 13, 2009
  • 2 more comments
  • Frank Zhang
    Frank Zhang May 13, 2009
    if you can catch the error code I can give you the detail reason.
    are you solve it?
  • Frank Zhang
    Frank Zhang May 14, 2009
    is this help you? please rating me thanks!
  • Frank Zhang
    Frank Zhang May 15, 2009
    is this help you? or feedback any question please!
  • Frank Zhang
    if all rams works normal that the system file damage in HDD, so you need reinstall OS to fix it.
    please take a rating let me know how much helped you thanks
    Scholar:
  • 121 Answers
U need to replace the memory.......open the memory dock at the bottom end of the notebook....have the battery and ac power removed......if there is 2 memory modules....remove 1 at a time reboot the system to check which 1 is giving you trouble....
if there is only 1 memory module ull need to change this
keep me posted
Acer laptop display is gone after blue screen came as physical memory dump.
try changing the physical drive to IDE or to the other option... if that doesnt help check your memory..
success
Jun 21, 2012 | Acer Aspire Notebook
Blue screen appears & keep restarting
It is possible that the malware is to blame, in which case a computer technician will need to sort it out.
I think it may be a bad memory module or loose memory module connection.
Take care!
damnor01
Apr 28, 2012 | Acer Extensa Computers & Internet
How do i fix a disc error on my acer aspire
Make sure you do not have any devices plugged in to the computer like a USB flash drive or a MMC. Usually what you have to do about that is to drain the power of the computer. Turn it off, remove the battery, unplug the AC adapter and then press the power button for 5 secs. Turn it on using the AC adapter alone. if you still get the same message, You will have to physically open the back of your laptop and reseat the Hard drive. If it still wont correct the problem, restart you computer and either press f2 or delete to enter the BIOS page. check if the HDD is properly detected and try to reload the BIOS defaults. now if any of these wont work, call ACER and most probably your Hard Drive is bad.
Jun 12, 2010 | Acer Aspire 3680 Laptop
I have an Acer Aspire 3680 and about a month ago I had to replace my hard drive because it said a failure was immiment. I ordered the recovery disc from acer and totally re-done my laptop. Well last night,...
Whilst this error can occur due to a faulty hard drive or corrupt page file, but is also a symptom of faulty RAM memory. Unless you have heard "clunking" noises from your new hard drive, its unlikely to be the new disk this time.
Re-seat the memory first. If you have two memory modules installed try removing one at a time (see page 67 of the manual here ftp://ftp.work.acer-euro.com/notebook/aspire_5600/manual/AS%205600_3680.pdf )
Check the System Log in Event Viewer for additional error messages that might help pinpoint the device causing the error. Disabling memory caching of the BIOS might also resolve it. Finally, if all the above steps fail to resolve the error, take the system to a repair facility for diagnostic testing. If you the laptop is overheating, or you can't hear the fan running then fan failure might also be a possible cause.
Dec 11, 2009 | Acer Aspire 3680 Laptop
Problem when i open my acer aspire 3680
if you want to become well again the performance of computer / laptop you will need to re-install the windows and still re-format the C drive, the error is often obtained by virus and deteriorative system32 of windows, good luck
Jan 08, 2009 | Acer Aspire 3680 Laptop
All Drivers for Acer Aspire 3680
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
2 problems in one
Depending on what operating system you are using, I suggest repairing the operating system. For windows xp here is a guide that you can follow http://www.michaelstevenstech.com/XPrepairinstall.htm.
For windows vista
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Apr 16, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
155 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
