I am java beginner and I want a help in writing a java program to calculate the variance for an array of numbers
  • 249 Answers
The best thing to do here is to separate the steps for calculating the variance into different functions. To compute the variance the first thing to do is to compute the mean or the average of the numbers in the array. so your first function will loop through each of the numbers and divide it by the length of your array. the output is the returned. The next thing to do is create another function for the variance. loop through each of the numbers again and subtract to each number the mean. square the value then add to the previous. so that means you have another variable that starts from zero and just adds the answer. after that divide it by the length of the array again and what you are going to get is the value for the variance.
Posted on May 26, 2009
Write a program c that declares an array of 100 elements to hold these values. Read the values in from the file and store them in successive elements of the array. Keep track of how many numbers are read...
That appears to be an intermediate question in a programming class. Best read the book, the answer is not what is important the process of getting the answer is what you are trying to learn.
May 17, 2017 | Office Equipment & Supplies
"Stack overflow at line 0"
b> A stack is a section of memory where a program stores its variables, calculations, option states and program parameters. When started, a program is allocated some memory to use for the stack; a stack overflow happens when a program exceeds its allocation. The offending program may attempt to write into adjacent memory sections, causing conflicts with other programs. Stack overflows are common with Java, C++, Perl and other runtime environments, which assist in running programs. A stack overflow at line 0 indicates that the offending program tripped up from the start; however, stack overflows can occur on any line number.
Click "Start," "Control Panel, then "Internet Options." Click on the "Advanced" tab. Check "Disable Script Debugging (IE)" and "Disable Script Debugging (Other)" under the "Browsing" options. Uncheck "Display a notification about every script error." Check "Enable Automatic Crash recovery." Click "OK." Download and install a Java update from the Java website. http://www.java.com/en/download/manual.jsp Download and install a Windows update. Hope this helps.
Dec 24, 2012 | Microsoft Windows XP Professional
Sample variance on Sharp EL-738
To calculate this you press ALPHA (the green key) and 5 or 6 depending on if you want sample variance (ALPHA 5) and for population variance (ALPHA 6).
Jul 17, 2012 | Sharp EL-738 Scientific Calculator
I wanna to learn java and oop programming
Writing code is a skill that needs to be developed like any other craft. Start simple, and do it. Watching other people writing code isn't enough. Adjusting other peoples' code isn't enough. You have to write your own code, that solves your own logistical problems. They can be made up problems, but the practice of problem solving is the fundamental basis of coding.
core java training in chennai Best Core Java Training in Chennai Core Java Online Training
Sep 03, 2011 | Computers & Internet
Code for method parseInt() in java
parseInt(java.lang.String, int)
This code takes two arguments, a string constructor from the Java language and an integer. Its purpose is to parse (meaning de-construct or disassemble into component parts) one data type into another.
Here is an example of a Java program to specify and print out the dimensions of a rectangle, taken from the page http://www.roseindia.net/java/beginners/entervaluesfromkeyboard.shtml:
class Rectangle{
int length, breadth;
void show(int x, int y){
length = x;
breadth = y;
int calculate(){
return(length * breadth);
public class EnterValuesFromKeyboard{
public static void main(String[] args) {
Rectangle rectangle = new Rectangle();
int a = Integer.parseInt(args[0]);
int b = Integer.parseInt(args[1]);
rectangle.show(a, b);
System.out.println(" you have entered these values : " + a + " and " + b);
int area = rectangle.calculate();
System.out.println(" area of a rectange is : " + area);
Apr 09, 2009 | Sun Java Programming Language (cdj-275)
I'm interested to learn more java programming but I do not no wer
I advice you to start from this site:
http://math.hws.edu/javanotes/
and watch this video:
http://www.youtube.com/watch?v=KheL6umdW-s
try googl.com and write:
java programming
Nov 21, 2008 | Computers & Internet
C++ program for insertion, deletion in linked list and 2d array pls send the details for linked list so that i can understand it the best..considering me as a beginner.
program for deletion
#include<iostream.h>
void main()
int a[10],i,n,x;
cout<<"\n\t\tPROGRAM TO DELETE AN NUMBER FROM AN ARRAY";
cout<<"\nEnter the size of the array:";
cin>>n;
for(i=0;i<n;i++)
cout<<"\nEnter the number:";
cin>>a[i];
cout<<"\nEnter the position to be deleted:";
cin>>x;
for(i=x;i<n;i++)
a[i]=a[i+1];
for(i=0;i<n-1;i++)
cout<<a[i]<<" ";
Oct 13, 2008 | Computers & Internet
Source code for word count
Haha, i wrote one of thee a while ago for a competition. You need to us e the char at function mate :D
Inside a for loop
Ill havea look for you though :D
Sep 09, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
Java programming
I ll give you some reference book names for core java they are the best,
1)Head First Java by Kathy Sierra & Bert Bates
2)SCJP 5.0 by Kathy Sierra & Bert Bates
the first one is the best for the beginners read it before you go for any other
good luck
Aug 14, 2008 | Sun Java Programming Language (cdj-275)
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
