Question about Mitsubishi WS-55809 55" Rear Projection Television
My tv seems to have numbers burned on the screen
I just inherited this tv. It seems to work fine but there are lines and numbers burned on the screen in places.
  • teescrevo May 13, 2009
    What does that mean?
    Champion:
  • 453 Answers
U have a burn picture tube
Posted on May 13, 2009
  • Jose Garcia May 14, 2009
    need to replace tubes , but they no longer avelible , and is to xpence ,
DEAWOO TV Model no DTC 2975 vertical line i want to know that vertical ic number b,cos of that ic is burn & blast,i can't fine out.
If you have a bright vertical line down the screen you have an "S" correction fault. Usually there is a small choke that gets a dry joint under it.
Check for dry joints.
Jan 04, 2011 | Televison & Video
I inherited a Sharp LCD 32" flat screen TV that's only about 2.5 years old. It worked fine at its previous location. Upon bringing it to my house, I've tried disconnecting the cable from my TV &...
Try going into your setup menu. Look for a setting for "Cable/Air". Try switching it to Cable and then doing a channel search. If you are using a cable box try setting channel to 3 on tv. Those are the two easiest things I can think of off the top of my head without seeing it.
Jul 09, 2010 | Sharp LC-32SB21U 32 in. LCD TV
Picture goes to a single horizontal line.
Your problem is due to failure of the vertical scanning circuits in your TV. This is quite common and is caused by aging components. Generally drying out capacitors
You got to be careful not to leave it on too long when the picture collapses, it will burn a permanent line across the screen.
If you are an electronics expert you can fix it if you get a schematic. If not please don't attempt to reapir it yourself since there is high voltage in side the TV.
The problem may get worse with time.
Mar 13, 2010 | Toshiba 32D46 32" TV
Panasonic DMR E20 Produces a line of distortion along the bottom
Sounds like you see head switching from the tape. Most TV are over scanned enough to hide it.
Aug 30, 2009 | Panasonic DMR-E20 DVD Recorder
The tv is showing red lines on the screen.
These are retrace lines. The screen on the red tube is turned up too high. Inside the set there are 6 knobs. 3 for focus & 3 for screen. Turn down the red screen until lines are gone. These knobs are usually found by pulling of the front panel.
Apr 06, 2009 | Televison & Video
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
I dropped my 32" Samsung LCD LNS3241D and the screen cracked help
i will buy th broken tv, i have the same tv but with power and inverter problems. let me know.
thank you
Jan 15, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Green TV with lines through it
require model number of unit and how often this happends
Jul 16, 2008 | Samsung DLP HL-P5663W 56" TV
Caption
go into setup and second line from bottom make sure cc is off. (looks like a little vhs tape)
Oct 20, 2007 | Panasonic CT-27G5 27" TV
Mitsubishi WS-55809 55" Rear Projection Television Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
