The vehicle main audio harness (not the vehicle to OEM radio jumper/adapter short harness) connector has a numbered 16 pin connector of which 15 positions have wires. By position they are
1. Yellow with Blk dashes, 2. Blk/Brn 3. Blu 4. Blk/Wht 5. Brn 6. Orange 7. Blu/Brn 8. Red/Blk 9. Grn/Brn 10. Red with Blk dashes 11. Yellow with Blk dashes (yes a second one) 12. Pink 13. Empty no wire 14. Wht/Blk 15. Grn/Blk and 16. Blk (main gnd)
I need to know specifically what function each of these wires serve
Sounds like you need a light tester. I would guess that at least 8 of the wires are speaker + & - the others will be Main power and earth Possibly electric ariel, Memory store and a wire for the anti theft circuit. Assuming the stereo is factory. Any Audio shop can perform a test to clarify the purpose of the wires Wouldnt worry about the blank its probably a position for a newer or different model to yours. Steve in the UK
Well, you basically have only 3 choices:
1. Pay the fee at the dealership
2. Purchase the high-dollar equipment that is required to perform the programming procedure
3. Forget about adding another key fob to tor vehicle.
TECHNICAL SERVICE BULLETIN
Group
90 - ELECTRICAL
Number
03-90-020
Date
October, 2003
Model
Elantra 2001-2004, Santa Fe 2001-2004, Sonata 2002-2004, Tiburon 2003-2004, XG(NNN) NNN-NNNNand XG(NNN) NNN-NNNN2004
Subject
SECURITY SYSTEM KEYLESS ADAPTER CABLE
This bulletin supersedes TSB # XXXXX
DESCRIPTION:
The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03 or newer) and Data Link Connector (DLC) Cable.
SERVICE INFORMATION:
The keyless adapter cable can be used on the following vehicles:
^ 2001 -2004 Elantra
^ 2001-2004 SantaFe
^ 2002 - 2004 Sonata
Did you find the solution on this? i have the same issue here., 2003 santafe
