Question about Garden
Weedwacker starts easy but will not run for more than 5 seconds .
30cc engine will not run more than 5 seconds. It starts right up time after time but it only runs 5 seconds. I have changed the spark plug, air filter and gas.
  • 41 Answers
May need to check for holes in fuels. Or fuel pump diapham is bad. If so replace carb., don,t waste money on carb. kit.
Posted on May 13, 2009
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Brand new weedwacker model#316-711370 first time started right up ran for awhile then just stopped,wont start at all now
#34 craftsman weed wacker manual
45.55.157.141/craftsman-weed-wacker-manual.html
100+ items - pdf download about #34 craftsman weed wacker manual ... Books Title
File Code
Craftsman Weedwacker Manual from Sears com
Free Craftsman Trimmer User Manuals ManualsOnline com
Aug 04, 2015 | Cars & Trucks
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
Engine will not run at full throttle. I replaced the plug, mixed new gas, replace the air filter and tried adjusting both throttle screws. the engine starts easy,and idles fine.
You could have a carbon problem try taking off your muffler and check for the exhaust port for carbon if so I would take it to a good small engine mechanic to get it removed as it is rather tricky as the engine has to be pulled apart.
Jul 25, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Trimmer will not start when primed and string pulled. When put starter fluid in carb. it hits and runs for a couple of seconds. Prime it and it will not start. Does hit sometimes but does not run like it...
There is dirt blocking the fuel supply to the engine. You need to strip and clean the carb, preferably fitting a new carb kit at the same time. Clean out all the passages and orifices by blowing them out, but be careful of loosing small parts like filter screens and screws.
May 13, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
What is the fuel mixture ratio?
this will run on 50-1 mix,,but i would run it on a 40 - 1 mix unless yuou use the right 2 stroke engine oil,,if you use car engine oil mix it at 40 - 1 look at it this way,,,its a 2 stroke so it needs oil or it will seize up and reck your engine,,if you put a little more oil in it will smoke a little bit more but it will never seize up,,,mine is 20 years old now,,,time speeks dont it?
Dec 02, 2010 | McCulloch 30cc 2Cycle 180 MPH Gas Powered...
Engine experiences extended cranking to start it at times
Listen at the fuel tank when the key is turned on. The pump should run for a short time and shut off. If it continues to run, the pump is worn out and should be replaced. The fuel filter should be replaced if it hasn't been done lately.
Sep 08, 2009 | 1988 Dodge D-Series Pickups
Troybilt weedwacker won't stay running. It starts
you may need to rebuild the carburetor.Check all the gas lines for cracks or leaks.Check the primer bulb if it has one.Then try and readjust the carburetor.If that still don't work,then try to rebuild the carburetor.
Sep 02, 2009 | Garden
Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
288 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
