Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a sears 19.5 42in cut - Model #917.270810 need to find part for a spindle (I think it is where the blade attaches to.
  • Jerry Cramer May 11, 2010
    What part do you need may be able to help you get what you need
Engine quite running after about 15 minutes. Then once you let it sit for 10 minutes and start it up again, it will run.
Posted on Jul 01, 2010
    Sergeant:
  • 201 Answers
Sears has a appliance and tool repair center some where in your area hopefully.with your model # you should be able to order parts from them no problem.try a web search for appliance repair center for sears in your area........gd lk. chris.
p.s spindle is indeed the drive shaft for the blade.
Posted on May 13, 2009
Model # 917.289072 19.5 42" When i engage blades it is very noisy like metal on metal It seems to cut ok but I don't want to mess it up more I changed blades and changed oil
Did you check the spindle assembly. I had one that cracked on my mower and had to replace it.It could be broken at one of the corners and this makes the blade spin off balance or not turn at all.Or a pulley could be worn or bent and the belt makes it rotate against the other metal parts.This happened because I hit some stones. They can damage other parts of the mower deck as well as ruin the cutting blades.You can do an online chat with SEARS parts too and their tech may have more info which may hepl diagnose the problem. Good luck,
Jean
May 27, 2015 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do i replace blade on kobalt 12dual bevil miter saw?
I don't know the model of saw you have but they are made for fairly rapid and uncomplicated blade changes as users will change the blade fairly often as they cut different materials.
Some saws have a spindle lock which once engaged means the bolt retaining the blade can be loosened with a single wrench and some saws need the spindle holding with a second wrench which is usually fairly thin, in the order of 3 or 4mm, to engage on two narrow flats machined on the spindle.
The blade changing process is a fairly intuitive one and if you take the time to turn the saw over and observe how it is assembled I think you will soon get the idea.
Feb 03, 2015 | Saws
Loss of power when blades engaded.
Remove deck belt from blade pulleys and Tri to spin blades by hand. If they don't spin freely, you probably need new spindle bearings but if you do need a new spindle I would replace the whole spindle housing... Just make sure the one (s) you buy has housing, spindle, bearings, nut and washer.
Jul 04, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What's your problem?sears craftsman mower deck
Sounds like the bearings or etc. are shot. Get a new complete
spindle and your in business.
Jun 26, 2012 | Sears Craftsman 46 in Tractor Mulch Blade
How can I determine if the spindles on my toro mower deck model 78261 need to be replaced?
is the blade on backwards?check the key on the pulley maybe the pulley is moving not the blade
May 26, 2012 | Garden
I need to replace a deck pulley spindle assembly for blade
if you have a owners manual it will tell you but if not go to your computer punchin make model and a choice of sites will come up also sears parts direct will help u on the phone or enter your modle make and a parts list will come up good luck hope this helps.
May 19, 2017 | Mtd Garden
Need a replacement splindle for Sears LT3000
The complete spindle is called a mandrel on sears site part number 192870 $47.24. You can also get the housing all by itself and reinstall the shaft and bearings into it part number 187281 $24.60. The shaft is what the blade attaches to and can be purchased separate part number 192872 $17.84. All these parts can be purchased at a local Lawn repair shop for less money just take in these part numbers or your model number with you.
Mar 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Deck is leveled, blades are fine,spindle not bent it still cuts
there was a problem with the lighter gauge decks [thinner steel], and the deck would actually bend inward on the left side. this would tilt the mandrel inward making the blade cut at a slight angle to the right blade - there is tool to straighten the deck [the left mandrel housing usually breaks, though] - some shops have this tool, others have never heard of such a thing - most sears l&g field techs have this tool in their trucks - i have the tool in my shop, but i have had luck with turning the deck over and whapping it a couple of times on the inside edge of the left mandrel until the blades line up
Aug 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Have to overlap about half my cutting deck to get clean cut.
A: Is the blade on right?
B: Is the belt on the pulley?
C: Is the blade tight on the spindle?
D: Does the spindle turn freely with the belt off?
I can't think of any other possibilities
Jul 03, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
241 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
