I have lint on my clothes when they come out of the machine. ---even when their are not towels etc. in load. I can't find a lint trap. It's an old machine . Any suggestions? i don't have booklet- Machine was part of the sale of house. Do you know where i can find a manual that explains the cycle and how they all work? Sincerely, Deb PS i had to click one from dropdown bar my machine is actually sears kenmore model # 110- 4121092 its top load very old machine I live in canada but any info you have would be greatly appreciated thanks again Deb
The lint filter should be in the agitator. Pull the softener dispenser off the top of the agitator and check for a filter. You might even find that the agitator shaft is very dirty. Put through a warm wash with a solution of 1 cup vinegar to one cup bicarbonate of soda and let it go through complete wash. This should solve the problem.
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint.
Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Check the pockets of pants and make sure there is nothing in them ....Take a damp cloth and wipe out the inside of the drum to try to get excess lint out of it.... also run a short wash with no clothes in washer to see if it cleans the washer out certain clothes such as towels should also be washed by themselves ...........
You have taken the necessary steps to reduce the lint problem. It seems they have not worked sufficiently. Another lint factor is due to HARD WATER. You may have to disassemble the washer and remove the inner wash tub. On the bottom of the wash tub is a self cleaning lint filter. It may be gummed up with detergent and lint not allowing it to do its job. It will have to be manually cleaned.
Be sure to seperate lint givers with lint taker, do not mix towels etc with clothes that are attracted to lint. Also be sure water levels are sufficient
try washing on a shorter time as this washer may have too good of wash action and the lint is fabric coming off your clothing
add more soap powder and do not buy the cheapest soap as the soap is important in the washing cycle of your machine
towels that are not too soiled brobably need 6 minutes at most on wash
if this machine has a delicate wash cycle use that for tee shirts etc
water pressure is important in rinse cycles
do you have high pressure and water only trickles in check water inlets on back of machine where the hoses screw on
good luck
