Question about Kenmore 24422 Top Load Washer
Filling/ Timer problem
I've replaced the timer since thats what I thought was wrong at first. Now with new timer in, From the start of the cycle, it won't quit filling, No matter what setting i put the load indicator on it doesn't matter. I can manually spin in passed that point and it will resume the washing cycle until the rinse section. Once again it will sit and fill to the point where it runs out the drain tube. I'm not sure if there is a pressure switch inside the load indicator or what the deal is. I have checked power to all switches and its exactly what its supposed to be, The charge for a tech to tell me something I already know is rediculous so here I am. Thanks for taking a look!!!
  • 5,911 Answers
There are a couple of things that can cause of the water to continue to fill. A defective water inlet valve that fails to shut off can cause the problem, but you were able to get the water to stop when you moved the timer selector knob. If the water inlet was leaking by, it would continue to run no matter what position the timer was in.
The next item would be a pressure switch malfunction. You were correct to assume this as a possible problem. The switch is located in the operator console behind the load level selector knob. Just remove the back panel of the console to access. Verify that the clear plastic air hose is still connected to the switch. The air hose is what detects the changing tub pressure from the air dome and shuts off the water at the appropriate level. If this air hose comes loose, the pressure switch never detects the change in tub pressure and the water continues to run. Sometimes to the point of overflowing. Over time the hose can stretch and become loose. The vibration of the washer eventually will cause the hose to fall off. If this is the case, re-attach the hose and place a small zip tie around it at the point where it connects to the pressure switch. Make the zip tie snug, but not excessively tight. This will keep enough resistance on the hose to keep it from sliding off again.
If the air hose is correctly installed, inspect the entire length of it to make sure there are no rips or tears. The hose cannot have any holes in it, or the air pressure leaks out. In addition, double check the electrical connections ot the switch by checking the contacts to ensure they are clean. If none of these preliminary steps correct the problem, you may have a defective switch that requires replacment. Hopefully you won't require any additional parts to fix your problem.
If you have any questions, please let me know. I hope you find this information helpful.
NOTE: When working inside the console, please UNPLUG the washer for your own safety.
Posted on May 13, 2009
My Roper washing machine keeps filling and draining in the final rinse cycle.The lid lock light flashes and the machine will not complete the wash cycle, just keeps filling, spinning and draining!
Depending on your model, it will either have an electronic or mechanical timer. If electronic which it sounds like, you likely have a bad board or control unit. If mechanical you will need a new timer.
My old washer was mechanical and I had to replace the timer several times over 18 years. My new Samsung is all digital so when it goes bad, will have to diagnose the circuit that needs replacing. Normally there is an error code on the LCD readout.
Mar 20, 2016 | Roper Washing Machines
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
Haier XQJ50-31 drum quit agitating or spinning
If the timer stopped advancing on one of my machines (laundromat owner) i'd assume it's the timer motor. Kind of like when a top loader has no final spin but otherwise runs okay i always suspect the timer mechanism. For me it's a simple check; exchange timers with a neighboring machine. You probably don't have that option. Unfortunately, I don't know the Haier Brand of machines so i could be wrong.
Dec 23, 2012 | Haier XQJ50-31 Top Load Washer
Whirlpool commercial washer stopped running mid
Most likely the pump is plugged with lint, pillow stuffing, a small object, or some other obstruction which is not allowing the motor to turn.
Oct 29, 2009 | Whirlpool Washing Machines
Washer spins out but will not fill or agitate
You most likely have a bad timer. If machine is filling properly, then the switch is bad.
Servicing the Timer
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Sep 03, 2009 | Kenmore 24032\24036 Top Load Washer
Timer knob
HI. the timer mechanism has failed. these timer control modules will run about 134.00. simply replacing this timer will fix your issue.
May 28, 2009 | GE Washing Machines
Not running through cycle
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Good Luck!!!
May 06, 2009 | Indesit WA 115 Front Load Washer
Kenmore will not agitate
The timer is the most common problem. Call any appliance parts store and tell them the model number and ask for price for new timer. Also call sears appliance parts and get price. But a new timer and install it.
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Older hotpoint washer
Sounds like a pressure switch problem not a timer. depending on the year and model they had alot of water level problems.
Apr 18, 2008 | Washing Machines
Kenmore 24422 Top Load Washer Logo
82 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
