Question about SanDisk Sansa e250 MP3 Player
My Sansa e250 won't charge all the way!! Help me!
Ok, i usually plug in my Sansa e250 in the computer over night to charge. But everytime i do it, the little batery thing at the bottem of the screen is red and a message flashes saying low battery. do i need a new battery?
  • Anonymous Dec 06, 2007
    I had the same problem. I fix it by connecting it to a USB with higher capacity (I switch from the Laptop USB to my docking station USB) and it did the trick. The manual says that it takes about 3.5 hours to fully charge
You leave your computer on all night just to charge a battery?  Most computers ( and yours may not fit this category) use several hundred watts just to run, which adds a lot to an electricity bill, not to mention greenhouse gases etc.  Get yourself a proper set of rechargables and their battery charger?
Posted on Oct 19, 2007
  • 626 Answers
Sounds like the battery may have come loose in the back, so its not charging.
Take the 4 screws out, remove the battery. The put the battery back in and try charging it.
Best of Luck.
Posted on Oct 14, 2007
My mp3 sansa won't turn on or charge.
If it freezes up, wont charge or just wont turn on... slide the power button up for 15-20 seconds then turn it on. That should work everytime. good luck
Aug 13, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 wont charge when plugged into the computer.
Sounds like the internal battery needs to be replaced.
Hope this helps. Good Luck!
Aug 07, 2009 | SanDisk Sansa e250 MP3 Player
first you have to turn your sansa on and go to the setting and then you have to go to usb mode and ptu it on "mtp"
then plug it back up to your computer and this time when you plug it up the computer will start detecting it and when add song use your windows media player
Mar 05, 2008 | SanDisk Sansa e250 MP3 Player
No light comes on, had it on the charger all night, and used the usb cord, now what?
what have happened? did it just stop work or
have u done anything or dropt it? i need more information if i gonna try to help ;p
Jan 18, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250 won't charge
I had the same problem - the player needs to be unlocked (the little switch on top) to be able to charge - pretty stupid if you ask me but what can you do
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
I cant get my sansa to work on my computer
maybe it has to do with the USB port being 2.0 or not, i had a similar problem but i restarted the computer and it worked,
Nov 26, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e250 wont charge all the way
Well ... i will show you different way to recharge any plear with USB recharge options...
Now... first sorry for my english but... iam from Bulgaria ...
second: you'll need a adaptor from GSM mobile with 5 or equivalent voltage output.Next step: remove part of cover cable on USB cable on mp3/4 and search for red cable it is "+" split with plus on the adaptor of GSM, next ... "-" it must be arround all cables on mp3's USB cable, split with "-" on GSM adaptor. Isolate fine and when you connect GSM adaptor into contact and USB cable into mp3 .. the mp3 will charge fine! Its possible and in manual of SANSA is writen! :) I try and successed!
congratulations - spellsingero, Bulgaria
Oct 14, 2007 | Audio Players & Recorders
Problem with charging
try performing recovery mode on the player then after performing recovery mode update the firmware of your player. Recovery mode is > Enable Hold Switch + Press Record Button + Menu Button
Oct 08, 2007 | SanDisk Sansa e250 MP3 Player
I can't turn on my Sansa e250!! Help!
Check the battery connection(s) in the back. Remove the 4 screws, remove the battery an re-connect it. Charge the device for a few hours. Best of Luck.
Oct 05, 2007 | SanDisk Sansa e250 MP3 Player
Need help quick with sansa e280
try switching your usb mode, do that by going into settings, this might help but im not sure
May 28, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
109 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
