Question about Belkin (F5D7230-4) Router (587009)
How do i switch the NAT settings
How do i switch the NAT setting from strict to open
  • Richard Eisenstein May 11, 2010
    Can you log in to the router?
  • 854 Answers
Try this
Posted on May 13, 2009
  • 5 Answers
SOURCE: set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
Posted on Jan 30, 2008
SOURCE: Change NAT to open
i have the same problem, ive looked at the thread its the same as myne but when i go on the virtual servers it doesnt say discription or imbound port it just says lan port publick port i dont understand :(
Posted on Feb 11, 2008
SOURCE: xbox nat settings
You need to enter the router configuration. How you do this varies by model, but usually involves typing your gateway address into a web browser. Then, you need to assign your xbox an internal IP address and activate port triggering or forwarding (depending on the sophistication of your device) to send information on the designated ports to the Xbox.RICHARDM69 Was this solution helpful? Show your Appreciation by rating it
Posted on Dec 14, 2008
Joed911
  • 4338 Answers
Open an Internet Explorer browser page.In the address bar type - 192.168.1.1
Leave username blank & in password use admin in lower case...
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...
1) On the first line in Application box type in ABC, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
3) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
4) Click on set-up and change the MTU Size to 1452 and click Save Settings...
5) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
IP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...
6) Also assign the DNS Addresses on the Xbox
Primary dns :- 4.2.2.2...Secondary dns :- 192.168.1.1
7) Turn off your modem, router, and Xbox...Wait for a minute...
8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect... Kudos! Thanks! If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
govinda123
  • 2260 Answers
SOURCE: My router nat settings are set to strict how do I
you will need to change some settings on the router.
reduce the MTU if the MTU settings on the router is 1500 then change1365.
Also you will need to open some ports on the router.
Click here for more info
Posted on Nov 29, 2009
My nat is set to strict and I have done all the port forwarding and open ports nothing works i'm very frustrated.
As you said your NAT is set to "Strict" I assume this is about the Xbox 360.
Put the IP Address of your Xbox 360 in the DMZ on your router. Anything in the DMZ is free of all firewall restrictions and all ports are open to this device. Once you place the Xbox 360 in the DMZ your NAT will be Open.
Thank you for using FixYa!
Mar 01, 2011 | Computers & Internet
How do i change my xbox nat settings from strict to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
Dec 30, 2009 | Microsoft Xbox 360 Arcade
Ok my nat type is strict and i am trying to change to open
You want the NAT open for X-box ?
For X-box you will need to open some ports on the router.
Also you will need to reduce down the MTU on the router to 1365.
That will work.
for this you will need to open the router set up.
Click here for more info about x-box and router settings
Dec 09, 2009 | Actiontec Computers & Internet
Bt home hub change my nat from strict to open
reduce the MTU. If the MTU settings is1500 then change 1365.
also you will need to open the some ports on the router.
Click Here for more info
Nov 22, 2009 | Computers & Internet
My router nat settings are set to strict how do I set them to open
Nov 21, 2009 | Computers & Internet
I need to change my nat type from strict to open
This router does not have the typical "strict or open" NAT types. Looking at the manual, it looks like what you want is NAT enabled and SUA only enabled.
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060420161739,420060816160116,420080815092146,420090427144843
Page 133 has the details.
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
Nov 18, 2009 | Zyxel P660HW-D1 Router
Change NAT to open
Go to portforward.com and then set your xbox to conenct using the DMZ option on your router.
Jan 20, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Strict nat settings
go to security tab on the router interface and deselect NAT button.
Jul 03, 2008 | NetGear WGT624 Wireless Router
NAT set to strict, can not play on xbox live. How do I set it to open?
Reinstalled software that came withrouter and went thourgh the reconnection steps.
Now the NAT is set to open.
Mar 27, 2008 | NetGear RangeMax WPN824 Router
Set nat to open
Jan 19, 2008 | Zyxel Prestige 660HW Wireless Router...
Belkin (F5D7230-4) Router (587009) Logo
237 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
