Question about Metra 1986 93 Ford/Mercury/Mazda Vehicle Wiring Harness
I HAVE A 1998 FORD TAURUS SEDAN MY ALTINATOR BLEW SO I REPLACED IT NOW I HAVE NO HEADLIGHTS,HEATER,DASHLIGHTS,BLINKERS,4 WAY LIGHTS, NOTHING AND IT WONT START, THE BATTERY IS GOOD AND ALL THE FUSES ARE GOOD BUT THERE IS THIS PLUG ON THE BRAKE PEDDLE THAT IF YOU MOVE IT AROUND YOU CAN HEAR DIFFERENT SOUNDS OF BLINKING LIKE TURNSIGNALS AND THE FOURWAYS CAN YOU POSSIBLY HELP ME ???????????
  • 31 Answers
The clicking sound you hear is normal. That is a switch to both activate the brake lights and active the brake interlock. The interlock click is the solinoid activating. Are you sure all the fuses are good? There are fusable links on this vehicle. They will look like gray wires going from the battery. Check your connections and try a battery from another car just for giggles. good luck
Posted on Jul 20, 2009
Diagram for battery for 97 ford escort sedan why does my battery light stay on when car is off
Had this happen to my orion years ago, think it was a fault in altinator(sp?). My old garage did a fix with an inline fuse that they installed. Worked until fuse blew but was ok after replacing fuse. Can't ask garage as it closed. Sorry can't help more.
Sep 06, 2016 | 1997 Ford Escort
My dash lights are not coming on and my tail lights are not coming on, but my blinkers, hazard lights, dome light, and break lights are working fine. all the fuses inside the car are fine, but there is one...
you have a short circuit somewhere that is causing the fuse to blow,it is most likely the headlights unless you have been messing with the dashlights,you will need to check all the headlight wiring to see if you can find the fault.......hope this helps......cheers
Aug 13, 2011 | 1992 Honda Accord
Blinker failure
replace multifuntion switch (turn signal switch)
Feb 05, 2010 | 1998 Ford Taurus
LIGHTS DIM FOR A SECOND AND GO BACK TO NORMAL!
the solenoid, it has a red power wire thats leads from the battery , check if the bolts are tight. See what happens, if nothing. Try replacing the solenoid. My car did this and changed out the solenoid, runs fine. Part $15 approx. You can replace it, easily done.
Jan 01, 2010 | 1998 Ford Taurus
1998 Ford Taurus Dash (Console) and Backlights are not Working
If the 15 amp fuse #20 in under the hood is good, suspect the headlight switch is bad.
see diagram at link below.
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=62901
Aug 15, 2017 | 1998 Ford Taurus
The headlights on my 1994 ford taurus sedan are too dim. Even the high beams are not bright enough for safe nighttime driving. Also, the daytime running lights are always on the high beam position. I even...
the lenses are most likely clouded over? yellowed? sometimes you can buy a kit to polish them, but I would recommend replacement, polish doesnt last long, and you will need to replace them anyhow. the DRL lights are operating normally
Oct 16, 2009 | 1994 Ford Taurus
1998 chevy blazer dashlights and background lights won't come on?
Dumb question but, did you try swapping out the fuse?
Mar 12, 2009 | 1998 Chevrolet Blazer
99 ford taurus headlight/blinker problem
sounds like a bad ground through one of your lights, the right front or rear turn signal bulb.
Dec 14, 2008 | 1999 Ford Taurus
1998 taurus ford sedan
the fuse is in the junction box under the hood and is a 30 amp which is colored green there should be a fuse for low beam and high beam
Sep 03, 2008 | 1998 Ford Taurus
1998 ford taurus looking at a 1998 ford taurus 4 door sedan
Ask them everything from when the last oil change to the headlight
Aug 15, 2008 | 1998 Ford Taurus
Metra 1986 93 Ford/Mercury/Mazda Vehicle Wiring Harness Logo
108 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
