Question about Whirlpool 18.2 cu. ft. Top Freezer Refrigerator ET18PKXG
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
HI. My Whirlpool Custom Series refrigerator's freezer is leaking water into the main refrigerator through a hole in the bottom of the freezer. There's a plastic 'catcher' for the water, and that attaches to a plastic water line (drain)at the back of the frige. This line is clogged, so the water is leaking into the frige. Where does this water line go? Is it supposed to go to a drain? The model number is ET18JKXSN05
  • imnotdeadyet May 13, 2009
    Interesting. I've never seen a frige that has this, but I am no expert. One thing, it seems to drain water all the time- and the frige doesn't seem to need to be defrosted- I don't see any ice. Can you think of a reason that this drains water all the time?
    OK, that sounds good. Found that there isn't a pan below the fridge, and the line was clogged. Where should the pan be? There's nothing under the fridge at all... might have to find where the line leads...
    President:
  • 1,489 Answers
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
Posted on May 13, 2009
  • Samuel Charles Spriggs May 13, 2009
    I based my speculation on the observation that the line was clogged and it was connected to the drain pan.
    You must have an icemaker.
    In that case, the line has to be the water line to your icemaker (and water dispenser if you have one). If water is running all the time, the line is leaking. This can be stopped by turning off the valve on this line.
    You don't see ice in the freezer because once a day a heater and fan come on and melt the small amount of ice which has accumulated in the last 23 hours. The resulting water is drained to the pan below for evaporation.
    The pan may be so well placed/fitted that it looks like the bottom of the refrigerator -- do you think that's possible?
Water leaking and freezing in bottom of freezer and leaking on the floor it is a whirlpool gold series model #GI6SARXXF04
sounds like your defrost drain is clogged up. it can be cleaned by taking off the metal or plastic panel and cleaning out the defrost drain hole. a steamer works best.
Dec 20, 2016 | Whirlpool Refrigerators
I have a whirlpool refrigerator model m#EB9FVBRWS05 and the water leaks from freezer, freezer not defrosting and frost buildup . How do I fix this problem?
There are three main components in a defrost circuit, the heater, the thermostat and the control device(either a timer or and ADC board). One of these are not working.
Dec 24, 2015 | Whirlpool Refrigerators
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
I have whirlpool imperial series refrigerator model et1lfkxkq03, which has freezer on top. Water from freezer is leaking into refrigerator. I cleared out the freezer and can't find the clogged drain.
You will probably have to remove the back panel, which is the evaporator cover. The defrost water drain is always at the base of the coil. **** the drain out and pour some hot water down it
Jun 22, 2011 | Whirlpool Freezers
Water leaking from freezer into main compartment. not equiped with ice maker.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 08, 2011 | Whirlpool ET1MHKXM Top Freezer...
Whirlpool Refrigerator ET21GM LEAKING water ALL OVER INSIDE
there is a drain under the coils in the freezer. it is frozen and the water has no place to go. hairdryer and a lot of patience. a hairdryer can melt a freezer /warning.
Jun 09, 2009 | Whirlpool ET1MTKXKQ White 20.9 Cu. Ft....
Interior water leak on model ET18PKX6HB1 whirlpool refrigerator
The drain is clogged up. Check the clear plastic line that goes from the back to the drip pan on the bottom of the unit.
Mar 30, 2009 | Whirlpool Refrigerator Inverter Box -...
Refrigerators Logo
761 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
