Press & hold the 'end of cycle' button on the right side of panel
for 3 seconds. Child lock button, you do the same thing again & it
locks. You dont want kids bathing in the machine, no. Pl rate me nice.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Whirlpool GHW9100L Front Load
Hi The drum is not spinning during the spin cycle - the motor is running - I therefore suspect the...
(More)
Hi The drum is not spinning during the spin cycle - the motor is running - I therefore suspect the drive belt has broken Please advise easiseast way to check this out and replace belt if it has broken Thanks
My GHW9100LW2 Duet washer seems to have the drum locked to where it will not spin at all. I have...
(More)
My GHW9100LW2 Duet washer seems to have the drum locked to where it will not spin at all. I have checked the belt and removed it, the motor works fine. Do I need to replace the bearings, and if so, how is that done?
My front loading washing machine, GHW9100LW2, Serial# CSR2103781 (purchased in July 2004),has...
(More)
My front loading washing machine, GHW9100LW2, Serial# CSR2103781 (purchased in July 2004),has started to stop in mid cycle and throw an F 11 signal, and the door will not open. If I cancel the cycle, re-set to Spin and restart it, it then completes the wash. However when the next load is installed the same glitch repeats itself. Can I program it out by perhaps changing cycle preferences or some other method??
