Question about Acer Veriton 7600GT PC Desktop
My motherboard is fried.
My acer computer won't go past the bios screen and I was told it is my motherboard. How much are these parts to replace?
  • 4 Answers
Check out Newegg.com or some of the other sites like it. You can get a motherboard but you will need to know what you're doing to get it all back up and running correctly. If you aren't sure have somebody do it for you. The boards are actually pretty cheap but it depends on what else you may need to go with it.
Posted on May 13, 2009
Motherboard won't boot past cmos
you are pretty much right it may be a corrupt bios, however before we come to a conclusion try isolating both Seagate Barracuda 7200 rpm 80gig ide hard drive and optical drive only and then see if it at least goes past the bios screen, if yes then the bios is ok and just needs to be resetted to defaults. dont expect it to load windows even if it goes past bios check as hard disk which helps to boot to windows would be removed. also in case if you are using 2 ram slots try connecting only 1 ram chip in 1 slot and then see if it goes past the bios test screen. do reply with results. Good luck.
Feb 08, 2012 | Abit Computers & Internet
Hi My computer won't Boot up it has a msi km2m motherboard I heard 1 beep itb does not display anything on screen not even the Bios does not appear the ddr is seatedv and tight I already changered the...
Hi Sue.
Remove the power cord from the back and then take out the motherboard battery for half an hour (you need to remove the side panel from the case to access the motherboard) after the half hour is up pop the battery back in and connect the power cord, see if that resolves the problem.
The fact that you can hear 1 beep indicates that all is fine so I doubt you have fried the BIOS chip.
Also, if you have a stand alone graphics card installed remove that and clean the contacts, then reinsert it.
Plesae post back if you have more problems.
Good luck.
Aug 12, 2011 | MSI KM2MCOMBOL-6738-010 Motherboard
Did I fry my ASUS A7V8X-MX motherboard? I bought an old computer(with this moboard) that was working. I opened it and put in my old HD to slave it. Rebooted to get into the BIOS (just to check things...
I do not think that this problem is to do with your Motherboard. If you had fried your Motherboard, you would not see anything when you started the computer, you especially wouldn't be able to get in to the BIOS if your Motherboard was damaged because the BIOS is accessed straight off the Motherboard itself. You will notice that if you take out all the Hard Disks in your computer, you will still be able to access the BIOS.
This problem is probably due to a corrupt Hard Disk. Maybe you set the old Hard Disk to the Master or whilst moving your computer you damaged the other Hard Disk. This problem is known as the Windows Reset Loop, your computer will not get past a certain point in the start-up process and will then restart itself and do the same thing over and over again.
This could also be caused by a problem in your BIOS, when you did the CMOS reset, it would have probably knocked out all of the stored data. When your computer is starting up, you must go in to the BIOS and check which drive the bios is set to boot off. Even though your Slave Hard Disk is set as a Slave, you can still set the computer to boot off this drive, and if this drive is corrupted it will not boot, it will go in to the Windows Reset Loop.
If the problem still persists, i recommend that you remove the old Hard Disk which you have put in and try and boot off the Master as a single drive. If this still doesn't work, set your other Hard Disk as the Master and remove the other drive and try boot off that one.
If you would like further assistance with this problem, pleas do not hesitate to contact me on Skype (Skype Username: fixya-support)
Thank you for using FixYa! Have a great New Year and please remember to rate this solution.
Warm regards,
BearWeb
Jan 01, 2010 | ASUS A7V8X-MX (90-M7A780-G0EAY)...
My acer veriton m661 desktop--i cannot set the time,checksum corrupt,possibly flashed with wrong acer bios-acer europe-any fix??
Examine the setup options to see if there's a failsafe mode or a BIOS reset/restore. Otherwise contact Acer tech support to see if they can provide a BIOS reset. You may have to send it to them. Older motherboards had BIOS on a 28-pin socketed chip called an EPROM. These could be ordered from various suppliers with upgrades, etc. I have not seen these in use lately.
Dec 12, 2009 | Acer Veriton M661 PC Desktop
Black screen,then test screen.Did the mobo or vid card fry?
if you fried a psu, it was probably caused by a motherboard fault.
You could try removing the geforce card, and try plugging the monitor into the onboard graphics port if it has One. These boards also suffer from bios chip problems, so a replacement bios chip may be another suggestion. failing any of this the motherboard is faulty and should be replaced.
Mike @ compurepair.
Jun 11, 2009 | ASUS M2N32-SLI Premium Vista Edition...
Motherboard boot up problem
Try clearing the cmos bios on the board there is a jumper on it
Jan 02, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
BIOS Startup Incomplete
Sounds like you motherboard is fried, more specifically your BIOS is toast. I would go about ordering another motherboard and rebuild it.
Sep 05, 2008 | Acer Aspire 5100 Notebook
Acer Laptop crashed
first do one think remove the battery and start the system after getting on press f1or f2 or f12 or del button to enter into the bios screen after coming bios screen set the system to default settings and save and exit the system its restart check its working or not, still same problem remove harddisk and boot from cd -rom it will go for some installation , if it not goes motherboard if it goes harddisk problem
Mar 27, 2008 | Acer Aspire 9500 Notebook
Password
that is because the password in question that you are trying to get past is the BIOS password most likely. Verify that your computer is turned off, remove power cord from back of computer, and find the jumper near the Bios chip on the motherboard. It will usually be close to the battery ( another option, temporarily remove the battery for about 30 seconds, then replace the battery into its proper position ). Be careful when you do this as some battery sockets are a pain to work with. Anyway in nearly all cases, the Bios reset jumper is located very close to both the battery and the bios chip ( firmware ). Removing the Bios reset jumper and positioning it one pin over from the initial position will usually reset the bios and get rid of the bios password requirement. Always put the bios reset jumper back into its initial position before re-appying power to the motherboard. Be careful not to leave anything loose lying around on the motherboard or in the case, else you might fry the motherboard..
Once you have successfully managed to get past the Bios password, then you should see the computer start to boot up normally and prior to Windows boot up and in the Bios routine you can configure the computer to boot to CD first. In many more modern situations, the motherboard is already configured that way.
Feb 23, 2008 | Computers & Internet
Acer Veriton 7600GT PC Desktop Logo
150 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
