Question about Canon ImageClass D880 Copier
Main roller has a piece of paper wraped around it
How do you take out the main roller. it has a piece of paper wrap on it
What "main roller"? the drum? The "Fuser"?...either way, instructions are to detailed to list here.
If you're talking about the drum....just order a new cartridge (easiest solution)
Posted on May 13, 2009
Paper is getting stuck in the fuser rollers
remove the fixing unit and clean the charge roller (aluminume roller) in case you are cleaned for long time this coudbe in black color clean well and refix it, the machine will be alright.
Jan 28, 2013 | Canon imageRUNNER C3200 Copier
Hi, my lexmark T640 is saying 202.06 paper jam, check rear door. i have opened it and there is no jam, there is no paper anywhere and have pulled all the trays out and there is no jam. what do you suggest?
This jam is refering to back door, jam in fuser (hot bit) Double check no paper is wraped around fuser rollers.
These machines have a fuser at rear if you look at he fuser from the back, on it you will see, two thick fuser rollers (ones rubber), paper runs threw these then it hits a little black switch (your machine thinks this switch is activated) and then a series(3,4) of small rubber exit rollers, this switch (between middle and left) can get damaged it also likely that a piece of paper is concertinaed in fuser.
Oct 20, 2010 | Lexmark T640 Laser Printer
WE HAVE A PAPER JAM ON THE BACK FUSER OF HP LASERJET 2420. A PIECE OF PAPER IS COMPLETELY WRAPPED AROUND IT.
You can attempt to remove the fuser from the machine to have better access to the paper inside. It is very easy to damage the fuser roller and film when removing a piece of paper wrapped around inside.
We recommend calling for service, but worst case is you try yourself and can't get the paper out then you would just order a new fuser.
We can get you the fuser. Just call 262-993-1551. We offer free shipping.
Sep 02, 2010 | HP LaserJet 2420 Printer
I had a piece of paper wrap around the fuser of my Oki C5650 printer. I have removed the paper (all of it.), but now it is displaying a 980 Fatal Error code. What do I do now?
I just had a service call with a 980 error. i removed the paper wrapped around the fuser roller but the error persisted. The only thing that cleared the error was to replace the fuser. I am not sure why but the fuser was shot after it had the paper wrap inside it.
There is no reset to clear the error. The only fix was to replace the fuser.
Aug 18, 2010 | Office Equipment & Supplies
After a paper jam, I got a code of SC 541 and copier will not completely turn on.
I am guessing... I had to get my magic ball out to figure out what kind of copier you have... You have a Richo copier? If that is correct you most likely have a problem with the fixing unit.
Nov 01, 2009 | Office Equipment & Supplies
Paper will not feed unless it is helped and the red alert signal is always on. Can you help?
probably have some debris interfering with your 'paper path'. probably one of the paper pick-up rollers- check the path, try to remove debris, and try again! blinking red led is prob. jam warning! all it takes is a little piece of paper, or other debris wrapped around a "paper feed roller' to mess things up!
good luck!
Oct 08, 2009 | Samsung ML-2510 Laser Printer
Paper is jaming put in new toner just three days ago. the paper feeds part away and then wraps around the roller. We have doubled checked our loading of the new toner cartridge.
Hello sir; Is the paper wrap around heat roller ? if yes, then check the roller has 4 to 6 paper separation fingers does it function good, if not, please tell us which roller is?
Jul 30, 2009 | Samsung 4725FN Black and White Copier
Paper Jam that pulls paper to the right and crooked then get error message no paper
Hello
You have either a rubber roller that has gone completely bad or more likely there is something still stuck in the printer - probably a piece of paper wrapped around part of the feed roller. Open it up and examine carefully with a flashlight. If you can't find any foreign objects then wipe down all the rubber rollers with denatured alcohol.
Jul 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
Paper jam 202 with no paper in printer
Also remove print cartridge and look behind it, if this machine has duplex unit installed you will need to lift it off that first to axcess all areas.
Check all doors are shut.
Nov 13, 2007 | Lexmark T642 Laser Printer
Hp laSERJET 1200 PAPER JAM
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
Oct 18, 2007 | HP LaserJet 1200n Printer
Canon ImageClass D880 Copier Logo
old marine
old marine
