Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
Pentair Legend fell on side before because the float was, indeed, filled with water - not this time... Any suggestions? Bag is clean and seems to be weighted properly.
  • 83 Answers
Have you looked at the swivels in the hose? If they get stuck, it can cause the tipping over. Check the wear on the tires also.
Posted on Jul 01, 2009
Pool cleaner floats in water
pool cleaners that twist,wheelie and flop over all most allways a problem with the hose, plastic hose gets a memory that needs to be relaxed once or so a week to keep knots and kinks from forming , also replace hose every 3//4 years to as they just get too beat up to work effectivly any more by then
Apr 14, 2014 | Pentair Legend II Pool Cleaner
Just bought a used legend and it seems to be In good shape. It needed a new bag. Bought one today and began using it. It picks up fine but after a little while it ends up o it's side and stays there. Any...
their should be a ballist weight inside the unit in the bottom. Be sure that is in place. Then check all the floats and be sure they don't have any water in them. Also make sure your hose leingth are correct.
Sep 07, 2010 | Pentair White/Gray Legend Platinum...
My Pentair legend pool cleaner is not moving
On this automatic pool cleaner, this is usually an easy thing to fix. First, make sure that your filter bag is clean and free of obstructions. Next, take of your head float and shake it. If you can hear water inside, you will need to order a new head float and install it. They are usually inexpensive and easy to replace. Make sure the hose floats are evenly placed and make sure that the cleaner is not getting too much pressure from the return lines.
May 25, 2010 | Pentair White/Gray Legend Platinum...
Our three year old Legend keeps tipping over while
Sounds like the head float just below the debris bag is bad. Check to see if it has water in it. If so then replace it. That float helps keep it upright.
May 23, 2010 | Pentair White/Gray Legend Platinum...
Legend frequently lies on it's side when not running and occasionally when it is. Bag is not full
Check the float on the unit and I believe you will find it full of water and will need to replace.
Jan 26, 2010 | Pentair White/Gray Legend Platinum...
Pentair legend 4 wheel cleaner - runs over its hose
check the white float on the cleaner. take it off and shake it, if it is full of water you will need to replace it. when they get water in them they make the cleaner heavy and it will tip of on its side.
Dec 20, 2009 | Pentair White/Gray Legend Platinum...
Cleaner won,t stay on its wheels and falls over on its side the ballast float is full of water
You need this float to keep the cleaner uprite, so you will need to get a new one.
Dec 01, 2009 | Pentair White/Gray Legend Platinum...
Not BACKING UP
The valve is called a back up valve but that jet of water just hauls the cleaner out of corners, but the unit itself dosen't back up.
Oct 14, 2009 | Pentair White/Gray Legend Platinum...
Pentair Legend Platinum Falls on it's Side
This condition often is due to bag being heavy with sediment or the ballast float on head has water in it. Try removing the head float and listen fot the sound of water while shaking it. If audible, replace float.
Apr 19, 2009 | Pentair White/Gray Legend Platinum...
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
177 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
