Question about Garden
I have an issue with my JD GT275. It won't start.
I have an issue with my John Deere GT275. It won't start. It is getting gas to the carb and fire to the plug. Any ideas?
  • 1 more comment
  • rich_barber May 13, 2009
    Thanks for the quick response. It has the Kawasaki 17hp. I opened the carb bowl drain and fuel came out several times. As for the compression, it has been running strong as of late. No noticable decrease in power. I'll check the fuel tomorrow and report back. Thanks for the suggestions!
  • JOE GREEN
    JOE GREEN Jan 18, 2014
    Ihave a GT275and my solinoid on the on the carb. was not getting power
  • Anonymous Mar 27, 2014
    code came up on my 4955 jd tracter and it is d5p and what dose that mean what is that problems
  • 86 Answers
Hows the compression ? Has it been sitting ? It could have a stuck valve .What engine do you have ?Did you try putting a little gas in carburetor ? If so did it run a few seconds ? If so its a carburetor problem ! Remove and clean carburetor .You could also have water in gas this will cause the same thing you can look in the tank and if you see a bubble in the bottom its water needs to be cleaned out and bowl of carburetor also needs too be removed and cleaned,Try these and give me results,hope this helps !
Posted on May 13, 2009
My jd 111lawn tractor wont start was mowing it just slowly died.now it will turn over but wont start
Sounds like a fuel issue. Check and make sure your gas tank has fuel in it. Then check fuel filter to see if it is allowing fuel to the carb.
Aug 15, 2016 | John Deere Garden
How do I tell what year my John Deere GT275 is. I bought at an auction. Also it needs a mower deck what one do I use
take all the details to a JD service center and they will help you with all that information
Jun 09, 2016 | John Deere Garden
How to replace drive belt on john deere riding mower gt275
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
John Deere GT275 Riding Mower Service Repair Manual
Oct 07, 2015 | John Deere Garden
John Deere Snowblower 1032 won't start. Obvious solution?
First dump the old gas and put in fresh. Clean or replace spark plug.
Put a squirt of starting fluid in the carb. If it fires the ignition system is good. Do this a few times because there is still old gas in the float bowl and fuel line. When the fresh gas gets to the carb it will stay running. If it did not fire with starting fluid the points and condensor will need to be replaced and maybe the coil.
Dec 14, 2013 | John Deere 826 1032 Snowblower Operators...
John deere mower Won't start
Sounds like the carb is varnished up and needs to be rebuilt. They make rebuild kits depending on the carb number and you can rebuild it.
May 05, 2017 | Garden
Jd X320 will not start changed fuel filte,spark plugs,and checked air filter
I assume it cranks, but won't fire up? Make sure the choke lever is moving the linkage in front of the carb. If so, tap the carb bowl lightly with a wrench. (That fixed mine once, and it never did it again) Have you had your valve lash adjusted? Be sure the carb is getting fuel. Pull the fuel line off the carb, and try to crank it... My X320 has 1,500hrs on it, and I have had great luck! Keep me posted, I want to help you get this figured out!
Oct 06, 2011 | John Deere Garden
Jonh deere ryding lawn mower won't start
try making sure your getting gas to the carb,and to the spark plug if you can choke it and try to start it but fails check the spark plug if its wet with gas then the plug is not firing or your ignition coil is dead also check for debri or foreign matter in the gas lines and filters but if it has set for awhile most of the time the jet become clogged in the carb but most importantly make sure the gas is good and free water dead gas can cause a problem of that nature.hope this helps.
Aug 26, 2011 | John Deere Garden
My john deere L130 riding lawn tractor has spark and gas going to the carb but wont start. it has new spark plug and fuel filter When starting fluid is sprayed into carb it runs till its burnt up and...
I had a JD 111 rider that may have had the same problem. Turned out to be the fuel line had a weak area and would **** together and not allow the fuel through. It's a cheep place to start.
Good luck!!
Jul 11, 2011 | John Deere Garden
Garden Logo
572 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
