Question about Dell W3201C 32 in. LCD Television
Delltv model w3201c colorblinksred,green,blue,white and error rpt
So i was using dvr and the sound flickered off it always does that then i turn of the converter and went out then 5 hours later i turned the converter off and it gives and error and goes repetly red green blue white error what to do and
also wat do you do if the sound flicks off?
    New Friend:
  • 90 Answers
This unit needs to be reset. To perform a master reset, do the following: there needs to be a component connected to the input jack. turn to the av station once on the av hit "619" scroll down and select master reset.
Posted on Sep 30, 2009
  • Ron Kabestra Sep 26, 2013
    if that worked please email me how do the reset thanks
Picture is black and white, but I have sound. I have red, green and blue plugins. The green one is fine, but I'm not sure which spots to put the red and blue wires in to fix the color.
blue is always in the middle and the green / red are on the ends. Black / white means you have the wrong matching cables. You need to make sure to match red to red, green to green, blue to blue.
Sep 09, 2011 | Sceptre Televison & Video
Hi Have Vizio Flat Screen and a Denon 3803 receiver. The Tv a Vizio 65 Inch flat screen was here. Out of the wall is a power cord and red,blue,green monster cable. Red and Blue is audio and green video I...
Red, Green and Blue cables together typically denotes a component video signal - an Analog, High Definition transportation for video. This cable does not carry audio, you need another cable to hook up audio between the DVR and receiver. You can use either an RCA stereo cable (red and white), optical-audio, HDMI, or a whole plethora of other audio cables. I would recommend optical or HDMI to get the most out of your system.
Jul 16, 2010 | Denon AVR-3803 Receiver
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
DVD has been disconnected from TV/DVR. What
You can use AV cables witch are YELLOW, RED and WHITE, S-VIDEO plus RCA (round with 4 pins and RED and WHITE) or component (RED, BLUE, GREEN) plus RCA (RED and WHITE)
Nov 06, 2009 | Cyberhome CH-DVD 300 DVD Player
Samsung television - HL-R5067W flickers green =DVR player
if this doesnt happen on anything else you may have a bad cable somewhere or even worse a bad dvr. check cables first.
Jul 01, 2009 | Samsung HL-R4667W Rear Projection...
I have model number AVR587 Dennon receiver which worked fine with my nonHDTV; however, I just purchased a new HDTV and since the receiver model does not have HDTV the audio goes through the DVR. The...
it sounds as if your using HDMI out of the DVR to the TV which is fine but the better way to do this is to use the Component connections (red, Green, Blue) plus optical or coaxial from the DVR to the reciever and Component connections (red, Green, Blue) out of the reciever to the tv
Jun 27, 2009 | Denon Audio Players & Recorders
Just need to know where to plug in the red, green and blue cords
The red-blue-green outputs of the cable box are COMPONENT video, and the yellow-white-red inputs on the tv are COMPOSITE video. Although the words sound almost alike and the connectors look similar, they are incompatible signals. You'll need to change either the cable box or the tv so they match. Maybe this would be a good way to rationalize getting that new home theater system! Or maybe call your tv cable company and ask for a different box with composite video output. Once the cable box matches the tv, you don't necessarily need to change the cables. If the connectors fit, go ahead and use the cables you have.
Jul 15, 2008 | Quasar SP-3235 32" TV
Dell W3201C: No picture, No sound
Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Dec 04, 2007 | Dell W3201C 32 in. LCD Television
Green Picture
I guess it's missing blue. Even if you see the blue crt working it's not enough and focalised. replace the coolant in it and also check if you have some coolant leak on the crt pcb.
Apr 10, 2007 | Samsung HCN436W 43" Rear Projection...
Dell W3201C 32 in. LCD Television Logo
115 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
