Question about Sony 55 KDL55EX720 3D LCD TV
Sony kdl55ex720 blink 5 times fix - Sony 55 KDL55EX720 3D LCD TV
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Sony kdl40ex650 3 time blinks
dear system board is defective you may change the complete system board 3x is DC alert fault
thanks
m Nasir
Feb 25, 2014 | Sony 55 KDL55EX720 3D LCD TV
5 Blink Sony KDL - 46HXZ729
samsung46inch led tv no on which control si no manual
Nov 22, 2013 | Sony Televison & Video
No picture and no sound
unplug everything. Plug one item in at a time and ensure you select the correct input. Test one item at a time to ensure it's actually the television causing the issue.
Also, when you turn on the television with the power button on the side of the tv, press the menu button. if you have a menu it's a settings issue.
lastly, if the power light is orange or red, and is blinking, this will indicate a problem with the television itself.
Mar 24, 2013 | Sony 55 KDL55EX720 3D LCD TV
New panel of sony tv kdl-55ex720 required
You have to contact the authorized service center for Sony to get a new panel.
Nov 20, 2012 | Sony 55 KDL55EX720 3D LCD TV
55ex720 blinking 4 times
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Sony 55 KDL55EX720 3D LCD TV
Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Jun 02, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
UPS for LED tv
The set need a UPS with minimum 500W load capacity
Apr 02, 2012 | Sony 55 KDL55EX720 3D LCD TV
My 32'' sony wega blinks 5 times
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Feb 17, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony 55 KDL55EX720 3D LCD TV Logo
185 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
