Question about Magellan RoadMate 700 GPS Receiver
Magellan 700 GPS wont find sattlites
Everything else seems to work, the correct detailed written step by step is there but the satalite wont connect...
  • Anonymous Jan 01, 2008
    frozen screen, stuck on one location....this thing sucks....there's no reset button on it anywhere???
I just got off the phone with India (Tech Service). I sent my Roadmate 700 for service in October. When it did not come back, I called 4x and had to prove I sent it in with a copy of the tracking number from UPS. It has taken 2 mos to resolve, but they are sending me a Maestro 4250, free shipping for $300.00. Their first offer was for a free 3100. I was told the Roadmate 700 series is discontinued.
Posted on Jan 03, 2008
The Map on my magellan program is wrong, I have satalite photos of a waterway, i am planning on taking a tirp on, but the map on my gps isnt correct, what can i do??
oh i got it. it's because of the map overlays right?
open the satelite photo on the computer with notepad and edit the correct latittude and longittute
i think that the first line is for up left corner 2nd line is for the up right corner and ex.
May 03, 2009 | Magellan SporTrak Map GPS Receiver
Everything works but the sound.
Mine does the same thing. You may need to do the 'reset GPS' trick. (hold down the - key and the repeat command key, then choose reset GPS.
For temporary, you can do the diagnostics>sounds (I think).
Mar 08, 2009 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS does not work properly
It seems that Magellan is not good with the power connectors on their units, I believe the problem is with the power adapter plugged into the cradle. Sorry I have no information about a repair center. Usually for an absorbent amount of money, Magellan will repair.
Dec 23, 2008 | Magellan RoadMate 700 GPS Receiver
Power wont come on
get a new unit like any magellan mastreo series 4000 or higher or roadmate 800 or higher,i had a 700 they start having alot of problems after i did my research on here.i have the mastreo 4000 and the roadmate 800 both work great.
Feb 23, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan roadmate 700 Does not track
Feb 15, 2008 | Magellan RoadMate 700 GPS Receiver
No signal, is this an antenna problem ? Or is the unit not worth fixing.
it is not worth fixing,i had a 700 it worked until it loses sattlite signals.then i did my research and notice how many problems the 700. i decided to get the magellan mastreo 4000 and i bought roadmate 800,so get a newer model you will be happy that you did.
Nov 25, 2007 | Magellan RoadMate 700 GPS Receiver
Sreen works not accurate (RM 700)
This seems to be a general problem with Raodmates - try tapping a bit firmer with your fingernail - if that fails then bin the Magellan as they are very unreliable and Magellan Support is very poor!!!!!!!!!!!!
Oct 19, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 GPS
If everything else is working fine, specifically the touch screen, then it's probably your speaker. open unit and check your speaker for anything stuck to the back of the magnet (on the speaker). make sure the cable going from your speaker to the keypad PCB (board) is pushed in all the way. you may want to even pull it out and re-connect it. make sure the unit is off while you do this and try to ground yourself with something. good luck and let me know how it turns out.
Mar 04, 2007 | Magellan RoadMate 700 GPS Receiver
My Magellan RoadMate 700 GPS Receiver won't locate my position.
If out of warranty time frame, open her up and check the grey cables that you will notice right after you crack the case. Make sure the cable is un damaged and connects to the main board (the big one) to the I/O board (attached to rear housing). If no change, then try resetting GPS user data. At User Menu (after reboot), press "-" key and repeat key at the same time. select reset GPS user data and cross your fingers. -Daniel
Nov 10, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
91 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
