Question about Compaq Presario 6030CA PC Desktop
Long flatlined beep when powered on
Hi, I really need some advice!  When I attempt to power-on my pc, I get a single beep and then a long unstopping flatline after that.  Is it dead??  If it would give me a phoenix code, that would be ok, but I get a long unstopping beeeep... and that's it, nothing else.  Fans are running, but no boot.  Please help!  Thank you!
    Genius:
  • 1,601 Answers
You may have a bad video card. put in another one to check
Posted on Oct 22, 2007
    Scholar:
  • 116 Answers
According to HP your machine should have pheonix codes. So i'm guessing that is very bad :)
Have you tried reseting the bios yet?
How about trying different memory, or just removing any extra memory.
Looks like you will have to TS this one old school. Trial and error.
Posted on Oct 14, 2007
Power on, One long beep, no keyboard/mouse or video
Hi there
if you are sure that you are only getting a single long beep then that would indicate a problem with either, the powersupply or the mainboard.
it is really difficult to advice you on what to do at this point because the error is only a long beep, you would have to bring the computer to me so I could take a closer look at it.
So I would recommend you take the machine to a local repairer for a diagnosis.
Jan 19, 2013 | Velocity Micro Edge Gaming Desktop PC ...
P5GD2 one post beep
Check the processor's heat sink fan. Make sure it's spinning. Blow out any dust or vacuum (w/ no power to the tower.) Reseat the memory. Try with one memory stick if you have two, resassuring to put in slot 1. Sometimes two different types of memory act weird together. Make sure memory is compatible. (ex. PC2100...)
Jan 01, 2012 | ASUS P5GD2 Premium (P5GD2PREMIUMWLOM)...
My a5 has no pressure with my flatline installed, and works fine with stock barrel... pleASe explain
Have you chrono'd the gun? This test velocity. This makes no sense unless your
gun is actually shooting VERY slow. In that case the way the flatline works, the ball rolls thru the barrel,
would really slow down a ball passing thru. That is my bet, low velocity. I use the same gun.
Adjust your allen screw in to make more pressure and try the flatline. Man I love the flatline with
an e-grip. Scares the **** outta the long distance players!
Here is your manual.
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
Feb 18, 2011 | Tippmann A 5 Standard Paintball Gun
I have power on but no display
Single 'beep' form PC on power-up? If yes, then try a different monitor. Either the MB is dead or the monitor.
Feb 24, 2010 | Dell (002TR) Motherboard
Hp dv6000 cant boot and the moniter is blank
the problem is in your motherboard it is a common problem of dv6000. and i think there is also a beeps sound. chat me at romsky79@yahoo.com
May 28, 2009 | HP Pavilion dv6000z Notebook
Hey my computer turns on all three fans are spinning and i hear a beep and then nothing no display nothing its really annoying ps:im no expert at computers so i dont no what the single beep means or...
One beep is good. Multiple beeps is not good.
Most likely you have a loose connection.
Generally if not the connection, the monitor has gone dead.
Possibly you have a defective Video Card
Unfortunately, you may have a defective System.
The first two are generally the cause of such problems.
Check all your connections in the back of the machine. A large Blue or White rectangular connector should be going to the back of the machine, these are color coded so the plug will go in, only one direction in only one port.
After making sure you are connected check your monitor power cable, assuming you get no Lights on the monitor at all.
After that: You may have to assume that either the monitor is dead, or that the video portion of the system is dead. This would require that you either replace the Video Card in the machine. If you get more then one single beep, you may have this problem
Or
This will require that you replace the System Board, if you are getting more then one Single beep you may have this problem.
Please let us know when all the connections are in order, so we can better diagnose the issue.
Good Luck
Apr 14, 2009 | Dell (2336V) Motherboard
Presario SR1103WM video dead
okay, if you go into bios, try to find where the video source is from or disable it from advanced to components to onboard, select disable
Jan 06, 2009 | HP Compaq Presario SR1720NX (EL435AA) PC...
Beeping wouldn't stop, now it's dead.
F7 means you relay board is bad, you need to replace it.
Jul 23, 2008 | Dacor ECS130 Epicure Electric Single Oven
Compaq Presaio S4200NX displays Compaq Splash Screen then a single continuous beep with but nothing else.
Most Compaq desktop that exhibits 1 long never ending beep indicates Memory error; Bad RAM. Corrective measure therefore would be replace and test.
You can try removing the memory and cleaning the gold pins with a pencil eraser and try again. If this doesn't work, guess you're back to replacing.
Good luck and kind regards.
Nov 04, 2007 | Compaq Presario S4200NX (DF215AR#ABA) PC...
Compaq Presario 6030CA PC Desktop Logo
64 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
