Question about Whirlpool GHW9150 Front Load Washer
Ghw 9150 lock mechanism problem
First the door would not open but the electronics thought it was unlocked. Now I got it open but I cannot get the door closed
  • maryumbrell Sep 28, 2008
    My GHW950 front load washer is acting strange I get A dl code and A F code, but I don't have A mannual do you have any suggestions where I can pick one up today. Thank You Mary
  • 1,294 Answers
Try some WD40 spray on the door
lock; on machine, not on door. And open & close for a few times with the power off.
Posted on May 09, 2008
Subaru door locks sound like they are unlocking and locking but they aren't
Sounds has if you have a fault wrong with the Mechanism motor inside the door.?
Apr 29, 2014 | 2010 Subaru Outback
Battery is DEAD on 2003 Ford Escape! Door key (using an actual key) unlock is also motorized, which needs battery juice. I can't get into this car! I thought about putting jumper cables on the sta
Open the door manually with the key!
Many Ford Escapes have power door locks as standard equipment. This system consists of a lock switch, lock actuator and wiring harness. When you depress the lock switch, it sends an electronic signal through the harness to the actuator. The actuator moves an internal piston that either pulls the actuator hook down or pushes it up. The actuator hook connects to the lock rod, which either locks or unlocks the door, depending on which way you push the lock button. While this system won't work with a dead battery, the mechanical lock system remains unaffected by electrical power loss.
Insert the door lock key into the driver's door lock.
Turn the key counterclockwise one quarter turn.
Pull the door handle up until the Escape's door opens. Once the driver door is open, simply open the remaining doors by pulling the interior door handles until the doors open.
Aug 13, 2017 | 2003 Ford Escape
Whirlpool duet model # ghw 9400 lo.door locking problem.
One hour service plus $40 part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 14, 2010 | Whirlpool GHW9400 Front Load Washer
Passenger door will not open
I can think of two possibilities:
1) The electronic lock is malfunctioning and forcing the door to lock. From the inside of the car, try forcing the lock to the 'unlocked' position. If you can do this with your had, but it 'snaps' back to 'locked' then it's an electrical problem. Possibly the lock solenoid itself, or the BCM.
2) If you cannot force the lock to the 'unlocked' position, then it's some sort of mechanical problem - maybe the lock is just jammed. Try spraying oil into the locking mechanism from the outside and working the lock until it's free. Otherwise, remove the interior door panel and diagnose the mechanical lock.
Feb 01, 2010 | 2003 Hyundai Tiburon
Waher stopped with an sud code and will not do anything. water is in washer.
too much suds in washer--
try using HE detergent-
reset to rinse cycle I think will work-been awhile since I had that code-
ready to throw my GHW 9150 off a cliff-FDL codes-door locks up.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Electronic locks/ stuck door
Your door latching mechanism is loose or defective. or maybe Christines' deendent. Spookuy huh?
May 30, 2009 | 2004 Kia Optima
2005 Cadillac STS door problem... Front driver door wont open from outside, seems as if the electronic system isnt responding to release latch when handle is pulled? Anyone have similar problem? All other...
There is NOT a mechanical connection to the outside door handles on the front doors. There is an electronic "door popping solenoid" This is a electronic problem. I think there was a recall on this.
Apr 05, 2009 | 2005 Cadillac STS
The driver side door will not lock - the other doors lock and unlock using the electronic key, but the driver side door will not ock either electronically or using the key.
the lock mechanism itself of the driver side door is the problem.
you may try lubricating the lock mechanism and you might un-tangle what is binding in there.
something could have stuck in the locking mechanism.
tnx 4 using fixya,
Oct 31, 2008 | 2003 Nissan Altima
Whirlpool duet washer (ghw 9150 pw2) status indicated "control locked"
find button with lock emblem beside it hold down 3-5 secs
Oct 04, 2008 | Whirlpool Washing Machines
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
replace door lock and ccu sorry
Jul 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9150 Front Load Washer Logo
140 people viewed this question
Dan Webster
Dan Webster
Sal De
