Question about Sierra Online, Inc. NASCAR Racing 2002 for Windows
NASCAR Racing 2002 Season PC game for Windows will not install on my computers (3 separate systems) once I click install or try using the run command.
I had recently received the NASCAR 2002 PC game in the mail and, when I attempted to install the game onto my desktop, the installer would not initialize. I then tried to install the game using the prescribed RUN command, which also did not work. I had no luck doing the same when trying to install the game on my laptop and backup pc as well. The game indicates it will function with Windows XP, which is what I have running on all three of my systems. All of these computers have more than the recommended specs for optimal performance of the game. Also, there appears to be nothing wrong with the game disc. It's as if there is some sort of process that isn't being told to run when the installation begins; the install screen comes up, I click on install, and then the screen disappears and the process appears to self-terminate, leaving me with performing the back-up RUN command which basically follows the same pattern of failing to install. Please let me know if there is some way I might be able to possibly get the installation to work.
  • 7 more comments
  • jacobamccull May 14, 2009
    I'm not sure if I am running it in administrator mode, but I have tried running the .exe setup as opposed to the autorun option in the game folder; both do not work. Also, what is an msi installer?
  • jacobamccull May 15, 2009
    I installed the Windows hotfix at the link you indicated, restarted the computer, and tried to install by right-clicking on the Setup.exe and choosing Run as... and then selecting Administrator and still the program installation self-terminates. I did, however, notice that, within the NR2002 folder there exists the icon NR2002.exe, which I figured I might try out. It worked only to the point of my having to indicate my desired graphics, all possible settings of which it could not run...I usually use DIrect X 3D with the selection of my Nvidia GeForce 8600 GTS graphics card and the 800x600 resolution; but even this did not work.
    How do I run the game using Daemon Tools?
  • jacobamccull May 17, 2009
    I successfully mounted the game using CloneCD to create the game image and Daemon Tools to mount it; however, when the install screen came up immediately after the image was mounted, the process self-terminated.
    I had recently received the NASCAR 2002 PC game in the mail and, when I attempted to install the game onto my desktop, the installer would not initialize. I then tried to install the game using the prescribed RUN command, which also did not work. I had no luck doing the same when trying to install the game on my laptop and backup pc as well. The game indicates it will function with Windows XP, which is what I have running on all three of my systems. All of these computers have more than the recommended specs for optimal performance of the game. Also, there appears to be nothing wrong with the game disc. It's as if there is some sort of process that isn't being told to run when the installation begins; the install screen comes up, I click on install, and then the screen disappears and the process appears to self-terminate, leaving me with performing the back-up RUN command which basically follows the same pattern of failing to install. I have already used the method of creating as image of the game using a program such as CloneCD and mounting it using Daemon Tools still the install screen comes up, followed by the same self-termination of the process. Please let me know if there is some way I might be able to possibly get the installation to work.
  • jacobamccull May 21, 2009
  • jacobamccull May 25, 2009
    reposting / ekse
    solved - ekse
  • 13,433 Answers
Solution.
Posted on May 25, 2009
    Sergeant:
  • 138 Answers
Have you tried to install in administrative mode? If not, when you put the cd in and it begins to start, click cancel. Then go into my computer, go to the drive that the disc is in, clivk explore, find the installer file on the disc, right click, run as, and choose administrator
Posted on May 21, 2009
  • 1,183 Answers
If the game is not installing on any of the three computers you have, the problem is with the installation disk. Is it a original game disc or is burned copy or downloaded copy. You can try downloading this software
http://www.daemon-tools.cc/eng/home
It would run the game directly from the cd, instead of installing the same. If the same fails too, you would have to look for another copy of the game.
thanks
Proton
Posted on May 15, 2009
  • Mandeep  Singh
    Mandeep Singh May 15, 2009
    Follow the link below for instructions
    http://www.askstudent.com/techtips/how-t...
    Thanks
    proton
  • Mandeep  Singh
    Mandeep Singh May 17, 2009
    If the game did not mount and install as-well , then you need to download the game again. There is a problem with the game installer. Kindly look for another copy of the cd or download the game from a torrent . I would not be able to post the torrent link of the game on the forum as it would be against anti- piracy laws.
    Thanks
    Proton
  • 355 Answers
Hello friend
First let me know ...are you running setup in adminstrator mode??? Usually setup is not running in nonadmin mode..... well try couple of shoot on UAC off ( in case of Vista).
secondly explore your game folder and look for.exe and then run it instead of autorun file....Autorun file may be incomplete thats why game is automatically exit...
waiting for your reply
Posted on May 14, 2009
  • 2 more comments
  • Rohit  Asthana
    Rohit Asthana May 14, 2009
    One more thing you can do....
    try to update your msi installer through net and also direct-x ...hope this will help you....
    gud luck
  • Rohit  Asthana
    first you should run setup in administrator mode...because game will not install in any other mode
    right click on setup and run it as administrator mode... well if setup is in msi then install latest software from here
    http://www.microsoft.com/downloadS/detai...
    then see , hope it will work..
  • Rohit  Asthana
    Rohit Asthana May 15, 2009
    Well dear , after investigate your problem.. I conclude their is problem in exe of game , may be this is faulty during burning in CD...If you want to check it , i advised it to you , try to install same game in different PC like your friends PC, if it will install on them then tell me, I will give you some another way to patch up.....
    Good luck dear
  • Rohit  Asthana
    hello dear,
    I can understand ... you want to run it at any cost....but i suggest you to please run it on different computer then see , i am sured it will not run on them PC too...
2 Suggested Answers
soumen777
  • 183 Answers
SOURCE: i need the code key for NASCAR sim racing
06Y8-CR05-FIGH-TING-4FUN
Posted on May 17, 2010
Why do I need the original cd in to play an installed game
The original cd is required as a form of DRM so that the game cannot be purchased once and shared among multiple people
Jun 19, 2013 | Papyrus Nascar Racing 2003 Season for...
Im trying to run nhra drag racing2 on windows vista but I get a black screen when trying to play game although i can hear game music in background. the task manager screen says that the game is not...
Since the game was released in 2002 it may have a few problems running on today's systems. I would first try running it in compatibility mode. Right click on the icon you use to launch the game and go to properties. From there click on the compatibility tab. Select the check box that says "Run this program in compatibility mode for" and then from the drop-down box select Windows XP (Service Pack 3). Then click Apply and OK. Then try launching the game again and see if it runs any better. If not, try it again but in compatibility mode for XP (Service Pack 2). Good luck!
Jun 29, 2011 | Racing Nhra Drag Racing 2 for Windows
Cant race online says the server is incompatiable
You will need to download the latest patch to play this game online, you can get it here
Was this helpful? if so please rate my answer! :)
Dec 28, 2010 | Sierra Online, Inc. NASCAR Racing: 2002...
Lost Nascar Racing 2003 CD, have key code
u probbly have to buy another game or just torret the file
Mar 15, 2010 | Papyrus Nascar Racing 2003 Season for...
I havent played nascar 2002 in a long time and it got erased from my computer. I dont have the 20 digit key to install it. Is there a way to get one?
If you google online or surf the bit torrent sites i am sure someone will have a code or a key generator that will allow yo to access tha game. I hope this helps.
Dec 05, 2009 | Sierra Online, Inc. NASCAR Racing: 2002...
Cannot initialize video - new installation on more
Check these two things,
1. make sure you have latest directX drivers installed,
and
2. that your Video Card drivers are up to date.
the game box should tell you the minimum requirements.
to find out your Direct X version, you can goto Start > Run and type in 'dxdiag' without the quotes and press enter.
Sep 24, 2009 | Sierra Online, Inc. Sierra Sports: NASCAR...
I need the install code from inside the CD jewel case....
if its a cd key code your looking for then here
RAB2-RAB2-RAB2-RAB2-8869
May 09, 2009 | Papyrus Nascar Racing 2003 Season for...
Computer game with no instructions or manual
hi ........
yes u can get them from
http://www.answers.com/topic/nascar-racing-2003-season
u can also check the manual in the installation disk
please comment!!! and give ur rating
Dec 28, 2008 | Sierra Online, Inc. NASCAR Racing: 2002...
Sierra Online, Inc. NASCAR Racing 2002 for Windows Logo
571 people viewed this question
Top Sierra Online, Inc. Video Game Consoles & Games Experts
James Wishart
Edward Talavera
Edward Talavera
Charles Applebaum
Level 1 Expert
Are you a Sierra Online, Inc. Video Game Console and Game Expert? Answer questions, earn points and help others
