Question about Intel Desktop Board CA810 Motherboard
What pins do you plug the hdd led,power led,reset switch and power switch? on a intel ca810 motherbord any diagrams would be nice thanks
    President:
  • 1,623 Answers
Intel no longer offers interactive support for this board.
However i did find you a schematic of the circuits and product guide. It is in adobe format.
I hope this helps.
Posted on May 13, 2009
Power switch
You maybe able to download a motherboard manual from this WEB site and identify the connectors for the front panel.
http://devxstudis.org/int/intel+d865gkd+motherboard+manual.html
Jan 03, 2013 | IBM Computers & Internet
Wiring motherboard to a atx tower
The motherboard manual will give you a breakdown of the cast-to-motherboard connections for the board. They differ slightly from board to board, but the connections are almost always found at the bottom front corner of the motherboard. There will be connections for the hard drive LED, the power LED, the power switch, the reset switch, and on some, the speaker (optional). The power switch and the reset switch connectors , 2-pin plugs, are not polarized, meaning that they can be connected to their pins either way without issue. The Power and HDD LED plugs are polarized, as LEDs have a positive and negative. Get this plug backward and the LED won't work. These are also 2-pin plugs. The power LED usually has a green and white wire (Green is +) and the HDD is usually red and white (Red is +) . Some motherboards have color-coded pins -- DO NOT TRUST THEM IF YOU DON'T HAVE A MANUAL -- they are not always standardized. Some motherboards have small print on the board adjacent to the pins to identify them. You CAN trust these. Otherwise, go to the Motherboard manufacturers site and get the manual for the board. The model number is on the board and can be searched for. If the manufacturer's name is not obvious, Google the model number and it will usually lead you to the manufacturer.
Dec 17, 2011 | Intel Motherboard
Accidently un-setaed three jump switches --Power EW,Power LED, HD
If your talking about the pins on the mother board for the on power switch, HDD LED, reset, power led, and system speaker you would need to note the make and model of *********** board. If you look very closely you should see little letters for example , PWS, HDD,RST,PCS,PLED, These mach up to the pins on the motherboard. also most commonly the PC speaker has an open pin so it will be 3 pins long and not just 2. To find the make and model of a motherboard you can find a name and a group of numbers something like " Intel A33Y97 " and then google for more information if needed.
Apr 11, 2010 | E-Machines eMachines Desktop PC
I'd like to know the sequence to connect the following connectors:power sw, reset sw, power led, hdd led from the front panel to the motherboard (motherboard foxconn sis 651 m03. Thanks West
If your board is the one in this manual, the pins are located very close to the CMOS battery. Page 21 in that manual shows the diagram. Power LED is the top two left pins. Hard disc LED is the bottom two left pins. Power switch is the top two right pins. Reset switch is pins 3-4 on the bottom row. Pin 5 on the bottom is not used.
Apr 27, 2009 | Foxconn Computers & Internet
Number codes for giving connections to HDD led,Power led, Reset SW & Power SW to motherboard
Those are really tricky and always vary from motherboard to motherboard.
without the exact model no one will be able to tell you exactly. But I'd recommend that you start out with the power (pw) plug and try trial and error. The only ones really necessary are the pw and reset. the only 2 that are polarity sensitive are the HDD light and pw led.
Apr 18, 2009 | Intel Motherboard
Front panel ceonnctor
Intel® Desktop Boards meet the ATX motherboard design guide specification using a 9-pin front chassis header. Special attention is required when attaching the front panel connector from the chassis to the Intel desktop board.
Front Panel Header
Description Pins Hard Drive LED 1 - 3 Power LED 2 - 4 Reset 5 - 7 Power ON (Power Switch) 6 - 8Lou
Aug 25, 2008 | Intel D845GVSR Motherboard
Motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
Pin alignment on motherboard for led switches
Connecting the Front Panel Header
Table 6. Front Panel Header (J9H3)
Pin
Signal
In/Out
Description
Pin
Signal
In/Out
Description
Hard Drive Activity LED
Power LED
HD_PWR
Out
Hard disk LED pull-up (330 ω) to +5 V
HDR_BLNK_GRN
Out
Front panel green LED
HDA#
Out
Hard disk active LED
HDR_BLNK_YEL
Out
Front panel yellow LED
Reset Switch
On/Off Switch
5
Ground
Ground
6
SWITCH_ON#
In
Power switch
7
FP_RESET#
In
Reset switch
8
Ground
Ground
9
+5 V
Out
Power
10
N/C
Not connected
Apr 01, 2008 | Compaq (283983-001) Motherboard
Intel Desktop Board CA810 Motherboard Logo
223 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
