Question about Dryers
Dryer won't get hot.
How do I get to the thermal fuse? I think that is why my dryer won't heat.
  • Dryers Master
  • 8,220 Answers
Take the back dust cover off and the thermal limit is mounted on the heating element to the right. The fuse is on the left but if the dryer runs the fuse is ok. The high limit would be the problem. WHY? Because the limit is set to blow at 250F and its counterpart the small one near the top is set to blow at 300. The fuse will blow at 350f so there is a lot of redundancy built into the dryer.
NOTE: If the heaters element is good, the limits is good, the control thermostat is good and you paid the electric bill, then the timer can be the fault. Not likely but still a possibility so do not rule it out but let it be the last dayum thang you buy, not the first!.
Posted on May 13, 2009
    President:
  • 1,136 Answers
Hi, Most dryers have the theromstats and fuse in back. You will need to remove the rear panel. You can also test the heating element too (If it is electric)
If you do not see a panel in the back, the lower front panel will come off with two clips.
I hope this heps. If I can help more, please let me know.
Thanks
Vic
My Samsung electric dryer runs but doesn't get hot
Clothes dryers usually have one of three issues when they fail to heat.
Taking a good electrical meter ( with ohms readings), check first the heating element.
If it checks good, then try all of the thermostats and the fuse. (There may be as many as 5 thermostats.)
You will need to unplug the wires off of each of these items that you are testing before you test them.
Whilst you are looking, be sure to test the two hot leads from the circuit breaker box, because one of the two hot lugs is for the machine operation, one is for the heating element.
God bless your efforts.
Jan 19, 2016 | Samsung Dryers
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    Maytag Neptune dryer was always drying on high heat, now won't turn on
    see this causes and fix it. God bless you
    Power From The House
    Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
    Door Switch
    If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
    Thermal Fuse / Thermal Cut out
    On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
    If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
    Wiring
    Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
    Sep 27, 2012 | Maytag Dryers
    For Dryer Model LER7646EQ1, dryer runs but no heat, It could be the heating element, the thermal fuse or other. Also the dryer has been running hot.I do not know how to remove the front panel
    This sounds like a faulty thermal fuse or heating element. The fact that you said the dryer has been running hot could indicate that the heating element was making contact with the heater box or the high limit thermostat is faulty. Both the thermal fuse and heating element can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity means a faulty component. When necessary to replace a thermal fuse it is best to change the high limit thermostat as well. They will sometimes come as a set from a parts supplier. Really sorry for your trouble and I hope this helped. Best wishes.
    Sep 23, 2009 | Whirlpool LER7646E Dryer
    I have a kenmore 80 series gas dryer. it's not staying hot. sometimes it will and sometimes it doesnt. i replaced the ignitor on it and its still not working what do you think?
    This is probably the gas valve not working right. I would replace it. The ignitor is working and turning on the valve but it doesn't stay on.
    Sep 03, 2009 | Dryers
    The dryer is not getting hot.
    hello...The fuse you are refering of is the thermal overload fuse mounted on the heating element. The cause is typically from lint that has bypassed the filter landing on the element or blocked-up vent from a clogged vent outlet. either case if the dryer does not have enough air flow it will over heat. The dryer is designed to blow the fuse as a safety overload feature to prevent further damage. To fix this it requires dismantling the dryer, down to the heater coil duct where the thermal fuse is located. Depending on your technical skills you may want to have a service technician conduct this repair.
    If you have experience in dismantling a dryer, I recommend you first get a schematic of the dryer, heater element and fuse. Always disconnet the power from the wall before working on the dryer . Some dryers have two elements and 2 thermal fuses. Depending on the model you may have to replace the heating element as well. You will need a multi meter to check for continuity of the fuse to determine which one is good or not. If you still want to tackle the repair you will want to obtain the service manual for proper dismantling and reassembly of the dryer.
    Hope this helps
    Apr 05, 2009 | Dryers
    Whirlpool gas dryer runs but won't heat
    hi stella. yes the problem is with the thermal fuse. when you were cleaning the vent at the left. the thermal fuse is right there, on the air duct, a small piece of plastic with 2 blue wires to it . replace the thermal fuse . thanks the appliance doc
    Oct 06, 2008 | Whirlpool LGR7646E Dryer
    Fuses
    We have Kenmore Elec Dryer - Model # 8860293, 70 Series. Where is the thermal fuse located? Dryer starts and shuts off in less than 5 seconds.
    lantzer@hotmail.com
    Mar 08, 2008 | Kenmore 63942 Dryer
    Dryers Logo
    85 people viewed this question
    Top Dryers Experts
