Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Hello, I own a GE spectra xl44 self cleaning oven. recently my oven has started to smoke while cooking. I tried to use the self cleaner, however this only set off my fire alarm. I have cleaned all of the grease and food particals off the inside. However there seems to be some food particles located near the bottom burner that I can not get to. Any suggestions on how to clean this and not fill my house with smoke?
    Top Expert:
  • GE Master
  • 26,681 Answers
If you cannot get to clean it fully then open your windows, place a fan in the doorway to encourage the smoke to leave the house and put it on a cleaning cycle.
Use aluminium foil to line the base of the oven rack. That will stop this from happening again when your containers are overfilled.
Posted on Jul 23, 2017
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
jumptrout51
  • 3361 Answers
SOURCE: oven burner makes a popping or whistling sound during baking cycl
STOP>>>>STOP{>>>STOP>>>
You have a gas leak in the oven.
Get this fixed immediately.
Posted on Feb 21, 2009
  • 2976 Answers
SOURCE: Grease caked on the oven from a spill
First--Look for a couple release levers around the bottom of the oven. You should remove the bottom and scrape the spilled grease off. If you can't remove it, clean off what you can before using a standard ovencleaner. It will still need to be washed well before firing it up.
Easy Off Oven Cleaner has been around for years.
SOURCE: Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
Posted on Jun 08, 2009
  • 491 Answers
SOURCE: I have two burners that don't ignite
FIRST MAKE SURE YOU TURN OFF THE GAS AT THE MAINS , THEN REMOVE THE ALL BUNERS AND GIVE THE TOP PORTION A GOOD CLEAN WITH WARM SOAPY WATER TO EXPOSE THE SCREWS WHEN LOCATED REMOVE THEM AND THE TOP THEN YOU NEED TO FIND THE IGNITE WIRE FOLLOW IT TO ITS SOURCE CHECKING FOR ANY BREAKS AND ALSO CHECK CONNECTIONS . GOOD LUCK .
Posted on Nov 17, 2009
Testimonial: "Thanks so much, but now I'm a little scared, plus i don't know where the gas valve is. i think i will have to call a repair man."
GE XL44 Gas Stove & Oven: When using self cleaning oven can I put the stove cooking racks inside to clean also?,
Is this my wife asking this ? lol, i had the same arguement with her, dont leave the racks in, it will tarnish them possibly bend them,that stove gets up to 900 F
Oct 29, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
How to clean a ge spectra electra xl44 series stove. Just slide door lever from left to right, and turn oven to clean, and forget about it. ???? anything else to do ? Nothing to spray inside oven...
    Self Cleaning
  1. Remove oven racks and soak them in soapy water.
  2. Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  3. Let the oven do its work; it will heat for several hours, charring off baked-on foods
  4. Fast Cleaning
  5. 1 Remove oven racks and place them in soapy water to soak.
  6. 2 Preheat oven to 200 degrees.
  7. 3 Turn the oven off and spray the inside with oven cleaner.
  8. 4 Allow to sit for 10 minutes.
  9. 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  10. 6 Dry with a soft cloth.
Sep 16, 2010 | Kitchen Ranges
How do you turn off the self cleaning oven when door is locked on the GE Spectra XL44
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 14, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE spectra xl44 stove model #jgbp28bea2ct, when I turn on the oven the clean light winks and the oven does not heat up. please help
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 self cleaning gas oven willnot come on
heatman101
Feb 20, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have GE XL44 range. How long should i run self
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!!!
Dec 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do I clean a GE gas range (self-cleaning oven?)
What do i clean the burners with ? the round surfers is harder to scrub, what do you advice .
Apr 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Cleaning my oven
May
you have to take the racks out do not and i repeat dont use oven cleaner although there is a oven cleaner on the market for self cleaning ovens thats ok but do not use regular oven cleaner
you also may use a mild blend of baking soda and water then rinse
good luck to you
Dec 04, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,081 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
