Question about HP PSC 1510 All-In-One InkJet Printer
My hp psc 1500 printer reads out of paper and its not, how do i fix this???? i read where the gears need to be cleaned, how does a person do this. and if this dosen't work then what???? HELP
  • 433 Answers
First unplug the printer and wait about a minute then plug it back in. That should reset the error.
The HP All-in-One requires little maintenance. Sometimes you might want to clean the glass and lid backing to remove surface dust and ensure that your copies and scans remain clear. You will also need to replace, align, or clean your print cartridges occasionally. This chapter provides instructions for keeping your HP All-in-One in top working condition. Perform these simple maintenance procedures as necessary.Clean the HP All-in-One To ensure that your copies and scans remain clear, you might need to clean the glass and lid backing. You might also want to dust the exterior of the HP All-in-One.Clean the glass Dirty glass from fingerprints, smudges, hair, and dust slows down performance and affects the accuracy of features such as Resize to Fit.
1. Turn off the HP All-in-One, unplug the power cord, and raise the lid.
2. Clean the glass with a soft cloth or sponge slightly moistened with a nonabrasive glass cleaner.
Warning Do not use abrasives, acetone, benzene, or carbon
tetrachloride on the glass; they can damage it. Do not place or spray liquid
directly on the glass; the liquid might seep under the glass and damage
the device.
3. Dry the glass with a chamois or cellulose sponge to prevent spotting.
Clean the lid backing Minor debris can accumulate on the white document backing located underneath the lid of the HP All-in-One.1. Turn off the HP All-in-One, unplug the power cord, and raise the lid.
2. Clean the white document backing with a soft cloth or sponge slightly moistened with a mild soap and warm water.
Wash the backing gently to loosen debris. Do not scrub the backing.
3. Dry the backing with a chamois or soft cloth. Warning Do not use paper-based wipes, as these might scratch the backing.
4. If further cleaning is needed, repeat the previous steps using isopropyl (rubbing) alcohol, and wipe the backing thoroughly with a damp cloth to remove any residual alcohol.
Warning Be careful not to spill alcohol on the glass or painted parts of
the HP All-in-One, as this might damage the device.
User Guide 41
Maintain your HP All-in-One
Clean the exterior
Use a soft cloth or slightly moistened sponge to wipe dust, smudges, and stains off
the case. The interior of the HP All-in-One does not require cleaning. Keep fluids
away from the control panel and the interior of the HP All-in-One.
Warning To avoid damage to painted parts of the HP All-in-One, do not use
alcohol or alcohol-based cleaning products on the control panel, lid, or other
painted parts of the device.
Check the estimated ink levels
You can easily check the ink supply level to determine how soon you might need to
replace a print cartridge. The ink supply level shows an estimate of the amount of ink
remaining in the print cartridges.
Tip You can also print a self-test report to see if your print cartridges might
need to be replaced. For more information, see Print a self-test report.
To check the ink levels from the HP Director (Windows)
1. In the HP Director (or HP Solution Center), click Settings, point to Print
Settings, and then click Printer Toolbox.
Note You can also open the Printer Toolbox from the Print Properties
dialog box. In the Print Properties dialog box, click the Services tab, and
then click Service this device.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
To check the ink levels from the HP Image Zone software (Mac)
1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then
choose Maintain Printer.
2. If the Select Printer dialog box appears, select your HP All-in-One, and then click
Utilities.
3. From the pop-up menu, choose Ink Level.
Posted on May 15, 2009
HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Nov 03, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP psc 2210 printer has consistent paper jam. Screen reads: paper jam. Checked all obvious things and followed recommended steps to solve paper jams. No problems found but still won't print.
Please work through this article first. If that doesn' t work follow these instructions to do a partial reset., or use these instructions to try cleaning the rollers and make sure they move freely.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP psc 1315 ..... status reads "out of paper" but paper loaded
Check inside printer on paper tray, there is 'n switch thaat is stuck. Release it.
Jul 11, 2009 | HP PSC 1315 All-In-One InkJet Printer
My HP PSC 2355 tells me there is a paper jam
Request you to get it check with the engineer personally or their might be a piece of paper stucked somewhere in the corner. I tried the same and was fixed
Jul 02, 2009 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 1310 reads paper jam in control panel. There is no paper i
Click this link to solve your paper jam problems with your HP printer:
http://bit.ly/9ShIi2
Mar 12, 2009 | HP PSC 1315xi All-in-One Printer
Error reads cartridge is stalled..
gear tear on the motor side is the culprit. You can repair it with an epoxy to hold it firmly form the feeder shaft or replace it with a new one.
Dec 19, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
1,251 people viewed this question
Seeker5211
Seeker5211
