We have a BenQ DV3750 LCD television. It is three years old, almost to the day. It has never given us any trouble to this point, but I went to turn it on the other night and it wouldn't come on. Upon further investigation, I realized that the red LED indicator light that tells you it is plugged in but not on, was not lit. No buttons work at all, no lights come on, no indication there is any power at all coming to the TV. I've tried unplugging it and plugging it back in, but to no avail. It just appears that there is no power at all. I called BenQ, and all I got was "send it in at your own expense (both ways) and we'll quote you for $65 on how much it will cost for us to fix it." I'd rather buy a new TV than send it off for a blank cheque, but if you have any possible solutions, that would be great.
  • dckmusic May 13, 2009
    It was as I assumed and just got confirmation.
    Brigadier General:
  • 8,619 Answers
Hi
It has happened because the power circuit of your TV has gone bad, if you have opened your TV before and/or understands the risks involved while repairing a TV set then please check for the power transformer on the TV board. There might be chances that this happened because of a loose connector inside the TV set or due to leaky/faulty capacitors. I would suggest you check for the connections on the power circuit board using a multimeter. Also try to see if you find any burned components on the circuit board.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 13, 2009
Benq TV model dv3750 Pictures not clear maps like someone is burnt
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 12, 2016 | BenQ Televison & Video
Benq LCD Tv Dv3750 PSU model FSP 320-6F01
its better if you replace the whole power supply board rather than replace the burnt surface mount parts because commonly if the surface mount parts burnt out there are some shorted parts that cause that burnt and possibly repeat the problem..
Please rate..
Aug 25, 2012 | Vizio L32 32 in. LCD HDTV
Where may I buy a power supply for a BenQ DV3750? Thanks.
Ebay are a good source of power supply suppliers. And can be competitively priced!
Jan 27, 2011 | Televison & Video
I have a 37" BENQ LCD(model # DV3750), I was watching the tv and it poped then would not turn on. I called a tech and they told me it mabe the power supply, so i took the back off the tv and looked at the...
I have the exact same part burned at the bottom. I just used a long nose plier and bend the bottom so it touches the print board circuit. It works. I guess I could also use a soldering iron to fix it. But will see if this temp solution works or not.
Feb 27, 2010 | BenQ DV3750 Television
I lost the sound when I attached the speakers, can there be a short and how do I repair it, is there a fuse .
normaly dont have a speaker fuse inside, is sound circuit defective, needs to be repaired. go to local repair store to check-it.
Nov 22, 2009 | BenQ DV3750 Television
Internal cracked screen on benq dv3750
you cant falls under cusatomer abuse so you gotta pay for a new panel or buy a new one... btw, panels cost more than what yopu originally paid for the uin it
Jul 18, 2009 | BenQ Televison & Video
Blown power supply
If it's possible, install a small computer style fan and direct the air stream over the power supply. You should then get another 10 years out of it. Unit needs ventilation and cooling air. Hopefully, it isn't installed in tight quarters.
Jul 18, 2009 | BenQ DV3750 Television
Need to Buy a main system board/controler board for BenQ DV3750
Really Did not find a solution because we already know the problem. i.e the mani/digital board. BenQ will not sell us the part. We are still looking for a supplier.
NEVER NEVER Buy BenQ
Nov 15, 2008 | BenQ DV3750 Television
TV problem
The power supply is defective on your LCD and will need to b e replace or repair to the component level.
Service parts seem to be a bit hard to locate now a days.
You can write to jah2mil@hotmail.com for more info.
Aug 14, 2008 | Protron PLTV-37 37 in. LCD Television
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
