Question about Electric Demolition Jackhammer
I have a old electric 120vac jackhammer (not sure manf.)
Motor works but hammer has very little action. I have disassembled everything loks fine including piston ring. Should the crank shaft be submersed in oil.Should there be a vacuum in the inner cylinder?
Matt
    Problem Solver:
  • 10 Answers
Usally their is grease packed in the hammer part,you can usally see a plastic type bung(plug)on outter casing
Posted on Dec 27, 2009
How do I find Instruction manual for Hitachi 1700w electric Jack Hammer
Service Support or google for hitachi hammer and under the choice of images you have chance .
Jun 30, 2014 | Electric Demolition Jackhammer
How to fix a kango jackhammer 950x stopped working a little smoke came out, replaced brushes and still not working for one had come off the wire switched on still did not work?
http://project21designs.com/download/kango%20900%20&%20950%20manual.pdf
Electric Switch measure it the suppression capacitor A collector from the armature was come out and ruined the brushholder(s) only a cable break the electric field a problem.
May 01, 2014 | Hammering
Hitachi hammers and stop hammering while motor still runing
Or a wedge is broken on the drive gear or anchor and drive gear must ALWAYS be replaced together if the teeth are worn.
Mar 30, 2014 | Electric Demolition Jackhammer
Jackhammer is not hammering
Its need service if its anchor / drive gear is worn or the o-rings seals are worn, if its this model hammer make a trade-in service that in case its an old hammer like this model its not the model to service by your one the best option is trade-in by your dealer. if its handle this model
http://dasen-hammer.en.made-in-china.com/product/BMgJKvoEXFpm/China-High-Quality-11e-1500W-Electrical-Demolition-Hammer.html
Mar 27, 2014 | Hammering
Can not get braker bit out of dewolt hamer
Use a burner to make the work a little bit lighter but wear safety glasses by this job en een leather apron because of the hard metal pieces that can be come of the chisel sometimes if its an heavy machine unmount first the sleeve, from the machine if you have luck to find somebody with a bearing press can make it come loose , but if its handling a little demolition hammer replace the locking sleeve the drill guide is most times worn if you have used the right chisel for your machine.
Mar 06, 2014 | Electric Demolition Jackhammer
H45sb hitachi moter run but hammer and stop how can i fix it
If pos 22 980-707 is broken it does not function , also if pos 35 is broken 932-815 then also the motor drives but no hammer , also if pos 8 is not moving 987-705 because the lubrication is not good anymore if started leaking and if that happens the piece and all your o-rings will be worn by heating up because thefront ofyour hammer must be air tight all the way , a demolition hammer is made for lasting long hours but leaking although it is still so small its in a few hours inside becomes to hot for the seals o rings and lubrication and then there are Discussions for to get a Service Kit (H 45Sb) - ( 987-712 ) the hammer is to old for economic repair by others some parts are not anymore available, i know it where good hammers , but marketing technical changes in weight, more
more speed and less vibrations and for 7 years max parts in stock (not sometimes 15 years as before) and over that time its all discontinued demolition hammers are averaged of use of 6 years by normal usage.
Lubrication is not the problem but in front its must airtight otherwise
is bad for your arms and shoulders because its build for timing when its airtight.
Hitachi H45SB Hammer Parts
Feb 03, 2014 | Electric Demolition Jackhammer
Takes long time to start hammer function
If the hammer function works once it warms up, then it's not broken - it's probably just plugged up with contaminants. You may need to disassemble to clean it out, although first I would get some Electrical parts spray , unplug unit,and soak down the inner workings while MANUALLY moving the shaft in and out, alternating spraying and moving. Let it finish dripping, then use a heat gun on low setting or a hair dryer on high setting to dry out the internals, then try again. Repeat procedure until hammer function works, then lubricate. You need to get the junk out before you lube, or it will make a bigger problem.
Hope this helps!
Dec 17, 2013 | Bosch 11248EVS 1-9/16" Spline Drive...
Need to change the brushes in my chicago breaker hammer
If change brushes it has having its workinghours Use a service kit for your model if there is support for your hammer ??? on EBAY there is a set brushes parts are maybe hard to find for electrical demolition hammer of this brand.
Carbon Brushes Chicago electric UL breaker jack hammer NEW 46935 harbor...
Jan 30, 2011 | Electric Demolition Jackhammer
My jackhammer seems weaker than what it should be. it runs and functions, but doesn't sound as loud as it should, nor have the power it should.
if pneumatic, it needs to be oiled with some air tool oil into the air supply nipple, 4 drops a day when used
Aug 08, 2009 | Hammering
Jackhammer quit in middle of use
if it is an electric jack hammer the brushes in the motor maybe worn out. most ace hardware stores have a good selection of motor brushes. also check to see if the brush retension screw came loose this would also cause the same problem.
May 21, 2009 | Hammering
Electric Demolition Jackhammer Logo
1,098 people viewed this question
Top Electric Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
PHiBrOpTK
Level 1 Expert
Are you an Electric Hammering Expert? Answer questions, earn points and help others
