Question about HP OfficeJet 6110 All-In-One InkJet Printer
Message: Remove and check ink cartridge
I have removed and replaced the black ink cartridge but keep getting the same message.  Turning it printer on and off does not help.  In this condition, I can not scan, send out going faxes or of course receive faxes either and can not print even just using the color cartridge.
Tell me how to fix the problem or at least use the other functions of the printer/scanner/fax.
  • 10 more comments
  • Anonymous Nov 26, 2007
    Remove and check ink cartridge message appears when i power up.i have tried everything.unplug and still cant get it working
  • sue1 Nov 26, 2007
    I continually get a message stating, remove & check cartridge. I've changed the color cartridge & still get the same error. I've powered the printer off & on and get the same problem. Please advise. Thanks!
  • Anonymous Nov 30, 2007
    It keeps giving me the message "cover open, close document feeder cover",it won't let me copy.
  • xzcZXCzX Dec 02, 2007
    i put in the ink cartridge, and it comes up with a cartridge align problem
    what do i do?
  • genastylettp Jan 26, 2008
    Same problem with my All-In-One HP 6110... both cartridges the #56 for color, and the #57 or black ink are the correct cartridges, installed correctly, but it keeps prompting me to press enter to align cartridges... did so 30+ times and each time the page prints out fine except now the ink levels are low. Can't use scanner because I can't get it to stop wanting to align perfectly aligned cartridges.
    Have unplugged it, restarted, opened/closed door... etc. HELP!
  • kwoodsong Mar 04, 2008
    "remove and check cartridge" message keeps coming on. I have uninstalled the software and reinstalled, still, no luck
  • SOFOS Mar 09, 2008
  • Anonymous Sep 06, 2008
    In response to STP162, the exact message is "Remove and check cartridge.", displaying on the LCD of the printer itself. Accompanying it is an orange flashing "!" light below.
    I have tried several things, including changing cartridges, unplugging/reseating everything, and checking for jams.
    I once got a "Report job queued" message before it began the "remove and check" message again.
  • cynsib06 Sep 07, 2008
  • marines5 Oct 04, 2008
    My officejet6110 keeps saying remove and check cartridge. I tried
    cleaning the contacts and powering on and off. Nothing works please help
  • Anonymous Mar 17, 2009
    Remove and check ink cartrdge. Check left ink cartridge. It's been saying this for months and still working. Just the other day it decided to stop.
  • bosco_desouz May 11, 2010
    Where did you get the replacement battery from. Do you have the specs. If so would you be so kind as to let me have them.
Hi just fixed my 6110 hp by pulling out spring wire that is on right hand side where black ink cartridge gets inserted i think it was preventing a good contact
i did this after following all other help hints including cleaning heads etc and replacing with new ink now it works perfect hope this works for you too
Posted on Dec 24, 2009
I worked all afternoon and eve trying to find that battery on the 6110 All In One. It did not have a battery on the left side. Went to Circuit city and pruchased a new HP4380.
Decided to take one last stab at repairing before throwing in the garbage. Finished taking printer apart and found the battery on the circuit board. Took a soldering iron removed battery and replaced. Reassembled printer, with much difficulty, pressed the on button and same error message.
Last step before chunking - removed ink cartridges rubbed thumb on electrical contacts, replaced ink cartridges and everything works super.
Guess the kids now get a color printer......................
Posted on Oct 01, 2008
Message: Remove and check ink cartridge - icon1.gif Re: HP OfficeJet 6110 destroys my HP 56 ink cartridges regularly SEE BELOW..ALL VERY WELL BUT I STILL CANT FIND THE FLAT BATTERY REFERRED TO !!
There is a service trick, once the printer decides that the cartridge is
bad , you will never get it cleared. So if you open up the lid, as if to
replace the cartridges, you can carefully detach the hinge at the bottom
pivot and open the top wide open. On the Left hand side you will see a
round flat battery - you want to remove the battery and then replace it
after about a minute. Just be careful and ground your body to a metal
part of the case, have ALL cables unplugged before you do touch it and
be carefull as the chips on the circuit board are static sensitive. Also
try not to hold the battery by the top and bottom - it may short circuit
and you will have to replace it.
This will reset the ram and clear the error until it detects again.
If it immediately comes back, then you may very well have a failed printer.
OJ wrote:
> My HP OfficeJet 6110 multifunction printer destroys black ink
> cartridges every couple of months.
> I print very infrequently (about 10 pages in 6 months?) and the HP 56
> (original) cartridges, still with much ink in them, quit working after
> that time.
> I've got 3 damaged cartridges so far.
> Error message that appears after a couple of months is:
> Right Cartridge Incorrect
> The color cartridge is never affected.
> I have tried cleaning the contacts, printer reset routines, re-install
> printer firmware, etc.
> The only thing that works is to put in a brand new HP 56 cartridge, and
> it will work for the next couple of months.
> The first 2 times, HP gave me a replacement cartridge.
> Now that my printer warranty is over, they claim the printer is at
> fault and they will no longer replace a under-warranty cartridge that
> gets damaged.
> Any ideas what might be happening here?
> And is there a way to continue using the fax (for sending only) or
> scanner (with its auto-document feeder) without having to install an
> ink cartridge?
> Thanks.
Posted on Sep 17, 2008
    Scholar:
  • 132 Answers
What is the message displayed and is it showing on the printer or the computer?
Posted on Oct 16, 2007
Cannot remove wrong cartridge message from epson printer
If you have tried turning it off and on again, and the problem is still there, then the printers sensors that detect the cartridge type are not getting the signal they expect from the new cartridge. The electrical contacts are probably dirty with ink. Remove the cartridge and try cleaning all the contacts you can see on it and in the printer where it was.
Dec 21, 2013 | Computers & Internet
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
Lexmark 6170 Cartridge Error 50C How to resolve?
"Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 17, 2010 | Lexmark X6170 All-In-One InkJet Printer
I keep getting a cartridge 50C cartridge error on my printer. What can I do to fix it? I can't print just anything. The test printer works but I can't print anything else.
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
color cartridge.
Apr 07, 2010 | Dell A960 All-In-One InkJet Printer
Installed a black ink cartridge and the printer shows the message 'black cartridge missing' and also says 'cartridge error: error 50c'
Hi there Error 50c
Can only gave it a try.
color cartridge.
Nov 06, 2009 | Dell A940 All-In-One InkJet Printer
Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
"Remove and check color cartidge."
ok the problem is very common.initially remove both the cartridges.then unplug the printer from main outlet and plug back in.this will reset the printer circuit.then after u on the printer bring back the cartridge carriage to cartridge installation position.then first clean the circuit in the carriage that touches and sense your cartridge circuit with a damp cloth.both colour and black carriage circuit.then clean the cartridge circuit too even if its new.then install both the cartridges and close the door and off the printer again and on it after 30 seconds atleast.then check it should work normally.
Mar 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Cartridge Error, Error 50C
Hi there Error 50c
Dell gets this lots so have a try.
color cartridge.
Mar 02, 2009 | Dell A940 All-In-One InkJet Printer
Printer won't recognize black ink cartridge
make sure the contacts on the ink cartridge is clean, make sure the tape cover the contact is removed. install the cartridge till you hear a click. turn on the printer and let it check the cartridge, and go through the aligment of the printer.
Oct 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Error message 50c on printer
I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
Hope this helps,
MPTMPeru
Nov 11, 2007 | Dell A940 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
2,042 people viewed this question
Clive
Clive
