Question about Dryers
We have a whirlpool GEW9200LW1 We can get it to turn and off but te other functions just beep at us and do nothing When you push the holdto start button it just beeps and the estimated time display flashes
  • 460 Answers
Look like you have problems with your timer.
After you see this you will find out how simple it is fixing it your serl.
copy n paste
http://www.youtube.com/watch?v=1t6QTmDX6aE
Also I send you this diagram will teach you about parts n prices n more about your dryer
copy n paste
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=GEW9200LW1&mfgModelNum=&fkMfgID=3
"Was this helpful?"
Posted on May 13, 2009
Washer will not start
Havenison you tried pushing the door in case it isn't connecting .
Dec 26, 2012 | Whirlpool Duet WFW9050XW Washer
GEW9200LW1 DRYER TURNS ON BUT DOES NOT SPIN
Well first of all you may check out the Door Switch if it's defective then your dryer is not able to spin, it may interfere with your dryer drum's ability to tumble. Test your dryer's door switch. If it is no longer functioning than you need to replace it. you need a multimeter to check it. Post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | Whirlpool GEW9200L Electric Dryer
DUET DRYER MODEL NO. GEW9200LW1. DRYER WON'T SPIN. CONTROL PANEL LIGHTS UP, TIMED DRYING SELECTED, HOLD START BUTTON DOWN AND NOTHING HAPPENS. ALL I HEAR IS A CLICKING NOISE AT LEFT REAR OF DRYER. IT...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 11, 2010 | Whirlpool Dryers
I have a Whirlpool Dryer model GEW9200LW1. I have to push the start button 10-15 times to get it to start, then it may run 1 second to 20 min and just shut off with time in the display. then if i push...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 10, 2010 | Whirlpool Dryers
Model GEW9200LW1 "Control Locked" light is on and dryer won't start. How do I unlock the control?
you have to push and hold the button that has the lock symbol next to it. i think on this it is on the far right hand side on the control panel.
Mar 14, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9200LW1 - All functions work except it won't produce any heat.
usually the heater or the lint sensor is to blame. you just need to ohm them out.I can get either one for you. David
Feb 17, 2010 | Whirlpool LAB2700ML Pedestal Drawer for...
Controls locked
I'm not familiar with the specifics of this machine, but the bezel and Console Electronics (the subassembly clipped to the bezel that holds the circuit boards and buttons) on our Whirlpool GEW9200LW1 is a poor fit, and pressure on the bezel itself can activate the End of Cycle button, and subsequently lock the controls.
Feb 13, 2010 | Whirlpool LAB2700ML Pedestal Drawer for...
1991 model 665.1691591 shows cycle and options on display but when you push start just beeps twice and does nothing. When you push cancel/drain it shows two minutes on the display and does nothing. Tried...
My 665.1691591 was exhibiting EXACTLY the same symptoms. It was a bad door switch. This machine is a bit unusual in that it has 3 door micro switches.
Whirlpool part number 431823 repaired my machine. It comes with illustrated directions.
Nov 26, 2009 | Kenmore Dishwashers
Whirlpool Washer won't start door locked
Likely the ECU is failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Washing Machines
Dryer will not start after bulb burned out.
moch, the fact that the light is staying on when the door is closed leads me to believe that the door switch is the culprit. If that switch is not made you will not start. See if the pin is broken off. Start there and let me know. Catriver.
Aug 10, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
129 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
