Question about HP Photosmart M407 Digital Camera
Camera lens stuck
I bought my camera on-line, and when it was delivered it was just in a box wrapped in bubble wrap sandwiched in between two pieces of foam. The lense was already extended. I checked for debris, nothing there. Other than that I can't be sure because, I bought it used I don't know. Anything could've happen before. Please help! I would just like to make sure I tried everything before taking it to get repaired, because I have already spent more on fixing the camera than I paid for it.
    Genius:
  • 2,985 Answers
If it arrived in that state then it was improperly shipped -who ever sent it.
It implies it was shipped with battery in and switched on..
You did not say but the seller may even know the device was faulty.
Attempt for a refund - if that is not possible cut your losses.
A repair is not likley economic
Posted on Oct 15, 2007
SOURCE:
Is there anything i can use on my point and shoot camera to diffuse the flash
tape on a small curved piece of bubble wrap just be careful not to block any of the camera's sensors.
May 23, 2014 | Cameras
How can i wrap a vase so that it won't shatter nor scratch?
The best idea to wrap a vase i to use bubble wrap. You should first of all gather some bubble wrap or some clothes and put them inside the vase so to roughly fill its emptiness. Then wrap a lot of bubble wrap around the vase, both on the sides and on top and bottom, rolling the wrap round and round and fixing it with tape. make sure its well padded and soft on all sides and corners. Then place the vase in a small carton box that fits it entirely and fill the remaining space with more bubble wrap so that the vase won't have enough room to move around. Then close the box well and write FRAGILE in red on the box.
Jan 06, 2014 | Office Equipment & Supplies
Nikonos RS lens cover stuck
Try wrapping a rubber band around the lens cap to improve your grip.
Apr 08, 2013 | Cameras
Camera filter stuck on lenses
You can try using one of those rubber jar openers, if you have one handy in your kitchen. Or wrap a suitable size rubber band around the filter to improve traction.
If that doesn't do it, a good camera store should have a filter wrench for exactly this purpose. If you don't want to buy one, simply ask for a demonstration of the product, using your lens. Most clerks will be happy to remove one or two filters. If you bring in a large box of lenses...
Jul 12, 2010 | Canon Cameras
My sumsung diggital camera fell in water. The battery and the memory card work alright. But when i switch it on a bright orange light comes on the front of the camera and the lens wont open does anyone kow...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Did you dry the camera completely? If not here is the procedure to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
May 21, 2010 | Samsung L700 Digital Camera
Water went in my cnon powershot sd750 camera and i was getting dull and blurred images and when i turned the lens it stopped workingit became dead.its just blank now.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You would need to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
May 21, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Fall in the water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Did you dry the camera completely? If not, do this: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
May 23, 2010 | Canon IXUS 80 IS Digital Camera
Lumix DMC-ZR1 / DMC-ZX1 Digital Camera: My lumix dmc-zx1 got wet with normal sweet water t...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need to take out all moisture trapped in the camera. You could do this: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Did you dry the camera completely? If not here is the procedure to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs. Hope this helps!
May 17, 2010 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Water in my camera
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Did you dry the camera completely? You could follow this procedure to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs. Hope this helps!
May 17, 2010 | Fuji FinePix F610 Digital Camera
HP Photosmart M407 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
