Question about HP Pavilion dv2000t Notebook
HP laptop makes beeping sound but does not start
  • 1 more comment
  • bwkchong May 13, 2009
    It is actually when we try to turn the computer on. The fan is working and all that, but the computer does not start. We have to turn on and off a couple of times and it will then start. The beeping patten is three beeps, Long, short and short. THanks,
    Say we finally got the computer going after switching it on and off a couple of times...How do I do all these memory tasks?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Sounds like its not recognizing the memory, try reseating the memory one stick at a time one slot at a time and see if that works.
    President:
  • 2,653 Answers
Beeps are usually related to memory problems.
Try reseating the memory and also trying removing / switching the memory modules. Try booting just one at a time.
Let me know what happens.
Posted on May 13, 2009
  • RescueTechLA
    RescueTechLA May 13, 2009
    You just remove the memory module on the bottom of the laptop and then just carefully just remove both modules and then try booting the laptop with ONLY 1, test.
    Then try the other one. Just use common sense.
    ALSO if that doesn't work the dv2000 is part of a major recall. You can check if your model qualifies HERE.
Hp altec lansing makes a beeping sound while starting
Try running a registry cleaning program. That should sort the errors out
May 20, 2014 | Acer Computers & Internet
How to make the sound work in my hp pavillion dv 4000
Turn up volume. Is it muted? do you need drivers? Do you have headphones plugged in? Open Control Panel, Sound, You can start here: http://www8.hp.com/us/en/support-drivers.html Audio drivers found here: http://www8.hp.com/us/en/support-drivers.html
Dec 15, 2012 | HP Pavilion dv4000 Notebook
Long beep sound after laptop start ion hp nx9010
1 Long Beep: Memory problem
Explanation: There is a failure of some sort related to the system memory.
Diagnosis: The first bank of memory probably has a failure of some sort; this is usually just a physical problem such as an incorrectly inserted module, but may also mean a bad memory chip in a module. It is possible that there is a failure related to the motherboard or a system device as well.
Recommendation:
Mar 29, 2012 | HP Compaq Business Notebook NX9010
It wont cut on keep making a beeping sound
beeping sound means that you have a bad power supply. Normally when booting your laptop, the power supply supplies enough power to boot to the operating system. You consult HP to replace your power supply in your laptop.
Oct 19, 2010 | HP OmniBook XE3 Notebook
My HP dv1000 does not start. I checked both adapter and battery ( new ones), but still the problem persists. And the adapter makes a beep sound 2/sec, doens anybody know what it means. Please help me out.
i don't think it's your adapter which beeps, beep indicates Ram problem, does your laptop power on? if it does power on and you don't see anything on the screen then it is because of RAM. Try switching ram to other slot, or get a new ram.
Feb 01, 2010 | HP Pavilion dv9000z Notebook
Beep on starting the laptop
Try to take memory out and put it back in to make sure they are seated in the slots properly and no loose.
May 27, 2009 | HP Pavilion dv1000 Notebook
Beep sound
DEAR,
PL SEND INFORMATION OF BEEPS SOUND.
HOW CAN BEEP GENERATE .CONTINUOUS OR ONE BY ONE AND HOW TIMES.
IF U ARE GOING TO HP SITE CUSTOMER SUPPORT THAT GIVES PROPER SOLUTION FOR THAT.
Feb 24, 2009 | HP Pavilion dv2000t Notebook
Hp computer will start, all the lights come on but the screen is black.. also.. it makes this loud beeping noise 4 times?? whats wrong?
The beep is more than likely a beep code (sounds stupid and obvious, but they're there for a reason).
What make/model is your machine? We can look up the code by make/model. That will diagnose your problem.
May 16, 2008 | Sony VAIO VGN-N250E/B Notebook
Beep from computer
My lap is also dv6000 and i have no symptoms like that.
it seems some thing is going wrong inside. As your lap is under warranty you should contact your service centre, it will be free.
Thanks
Iqbal
Apr 06, 2008 | Acer Aspire One PC Notebook
3 beeps at start
hmmm...that's not good. works fine with no battery. I suspect your motherboard may be taking a vacation from working soon.
got backup for your HP?
Feb 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv2000t Notebook Logo
148 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
