Question about Kenmore Washing Machines
My Kenmore 70 series is throwing water at the bottom when the cycle starts right as soon as the machine starts filling up
  • 5,911 Answers
It sounds like the air dome hose may have come loose. This is a small plastic hose that connects to the lower right hand side of the wash tub and runs all the way to the pressure switch in the operator console. This is what determines your water level. The washer will begin to fill and then a flood of water starts pouring out from under it. You will need to remove the exterior case of the washr for full access. Just follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Look to the lower right-hand side of the wash tub and make sure the small plastic air hose is still attached. If the hose has come loose, snip a small portion off the end and re-insert it on the air dome. These hoses can stretch over time and become loose.
If the hose is still intact, locate the water pump directly in the front of the washer. You will recognize it by the two drain hoses attached to it. These pumps can develop cracks over time and begin to leak. If this is the case, the pumps are not serviceable and must be replaced. Also check the drain hoses for rips or cracks and make sure the hose clamps are snug.
Last of all, check under the center portion of the washer tub. If the tub seal is bad, you will see water tracks dripping on the top of the gearcase.
The volume of the water you describe sounds like an air dome hose, though. What looks like a major problem, can often be a very simple cure. Hopefully this won't require any parts.
To re-install the washer case, follow thse steps:
1. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have questions, please let me know. I hope you find this information helpful.
Posted on May 13, 2009
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
Hello, Have a Kenmore series 70 (capcity plus).
Note after reading a bunch of information. I went home and removed the hose from the Level Switch and "clean it", if you will and re-attached. Started a load, and bingo bango bongo, it work. Thanks for the insight.
Nov 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Kenmore heavy duty 70 series washer
The washer starts on a fill cycle. If it's not getting any water check the screens in the valve where the water line hooks to the back. If it is getting water but not filling up pull up on the drain hose. If it is to far down the drain it can **** the water right out of the unit.
Apr 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Top Loan - Fill Cycle won't stop when full
Does the water stop when you push the timer in or are you having to shut the spigots off?? If it stops when the timer is pushed in then you have a problem with the pressure switch. There are quite a few tricks to axcessing your machine's components but if you are handy ill attemt to help.
Jan 12, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
78 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
