Question about Refrigerators
Side by side refrigerator model #PSS26MSTA
This referigerator was purchased 1.5 years ago. The dispenser works intermitantly whereas when I push the lever with a cup, the power appears weak (the light is dim when it comes on, same thing with the green dots). When the lights get stronger, the water (and sometimes the ice) will function.
I read some posts that suggest the circuit board may be fried, and if so, can I replace this myself (this is a stainless steel model which didn't appear to have any easy access points)? If I cannot, or if this is another problem I cannot fix myself, is there a vendor in the Powder Springs, GA (suburb of Atlanta) that you would recommend?
Thanks very much.
  • Anonymous Nov 13, 2007
    Same symptoms. GE service called but would like to fix myself.
  • 447 Answers
90% of the time I find when the dispenser is not operational an new motherboard (located on the rear of the refrig in a smaller steel service panel) is faulty. This control costs around $150 at most parts retailers or available at It is fairly simple to replace this board, the connectors are all different sizes so its hard to miswire it, just be careful.
Posted on Oct 15, 2007
Some time the thing that flip the ice door open so ice can come out has a short in it disconnect it from the door inside the cover and see if the ice will try to come out if that works then that thing has a short and will mess up the elec power flow
Posted on Aug 01, 2009
Our kennmore side by side referigerator bought two years ago seems to have lot of ice in the freezer compartment. there is ice formed over the vents in the referigerator side and things (milk) is getting...
is the ice on the back wall or was the door left open?also send the model number,you'll find it in the fridge side on the right hand wall up near the ceiling,it will start with like 106. or similar
Sep 04, 2010 | Kenmore Refrigerators
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
Kenmore s/s f/f; ice dispenser working; water dispenser not
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it doesleave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there.
Oct 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Our PSS26MSTA SS water dispenser stopped working. The light works, it makes ice, it just does not dispense either water or ice.
If your lights go dim when you try to dispense ice or water it is most likely the main control board BUT IT CAN BE A CHEAP FIX! Behind a plate on the lower back of the refrigerator there is a large plate that has the main control board under it. There are two identical capacitors marked 470uf 25volt by the small transformer. If you see that the tops of these are pushed up AT ALL on top THAT is your problem. Use de-soldering wick and a soldering iron to remove them then replace them with 470uf 50volt capacitors and your problem is solved. Be sure to observe polarity on the capacitors. $2 permanent fix.
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice forming on condenser copper tubing GE referigerator
is your drain line plugged up under that coil? another thing to check is if the door asket pinched that wold allow ait to infiltrate into the freeze and freeze up the coil. remember to clean under the unit once a year to keep the unit working properly and not having to struggle to condense the refrigerant. Hopt this solution's work for you and have a Happy New Year.
Jan 05, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
The water dispenser has stopped working!!!
could be a water solenoid problem (at the back portion where water from the sink enters ), or a micro switch in the dispenser area problem.
also, check if u have a water filter. could be clogged already.
tnx 4 using fixya,
Oct 09, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
General Electric model # GSS25JSRFSS
if your appliance is humming then your motor might be out. Im not positive but i had a similar problem of the humming and clicking and the entire motor burned up. Might be a reason the lights are fading and such... Hope this helps
Jun 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
689 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
