Question about Poulan Garden
Poulan S25 Chainsaw - fuel line replacement
How many parts do I need to remove to thread the fuel line from the filter in the tank to the carb? It has to wiggle through several openings.
  • Anonymous Mar 29, 2014
    I need to remove the carb from my chainsaw and cannot seem to figure out the steps
    Problem Solver:
  • 11 Answers
Should only be top cover and access fuel line through filler cap with long nose pliers first remove line from carb
Posted on May 14, 2009
Diagram for fuel line routing for a poulan 2150 chainsaw?
The 2150 has a remote primer, so there will be three pipes, the pipe coming from the fuel tank with the fuel filter on the end is the main fuel tube, this fits to the connection on the carb nearest to the pump cover on the carb ( alluminium cover held with a single screw ) the other connection on the carb has a pipe to the shorter of the two connections on the back of the primer ( suction side ) the longer connection on the back of the primer ( pressure side ) has a pipe back to the fuel tank, so the primer pulls fuel from the tank, into the bulb, and dumps it back to the tank, it does not push fuel into the carb, this way you can depress the bulb as many times as you like without flooding the engine.
Jul 05, 2012 | Poulan Pro Chain Saw 46cc 20"
My Poulan 2025 Chainsaw fuel hoses have broke down and fell apart. I have new fuel line but do not know the hose routing. All I found in the tank was pieces of hose and the filter. Only one hole coming out...
Check out epartsreplacement.com and there is a video on there you can watch that talks about fuel line replacement. It is a very helpful video Tom. Good luck
Aug 07, 2011 | Poulan Pro Chain Saw 46cc 20"
Poulan 18" Wild Thing Chainsaw. replaced bulb,
Ok lets get the pipes conecterd correctly to start with, the hose comeing from the tank with the filter on the end, connects to the carb fuel inlet nozzel ( the nozzel neares to the pump cover held with one screw ) the pipe coming from the other nozzel on the carb goes to the short nozzel on the primer ( suction ) then the pipe from the longest nozzel on the ptimer goes back to the tank, once you have this correct, try the saw again. Change the filter in the tank, the carb screws will have some type of anti tamper device, this is why you only have a small amount of adjustment, you may need to remove these to adjust the carb properly, if there are any splits or cracks in the fuel lines the saw will not run properly.
Mar 05, 2011 | Poulan Garden
My Poulan will start up but then when I try and give it more throttle it dies or even when I let off the throttle to idle it will die. Is this fuel line o dos the carb. need to be cleaned? How do I...
It sounds very like a fuel issue, before diving into remove the carb check the easy stuff first, drain the fuel tank and fill with fresh fuel, pull the fuel hose out and check the condition of the filter on the end,any doubt replace it, check the condition of the fuel hose up to the carb for cracks or signs of age. Let us know how you get on
Jan 26, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need to know how to connect the gas lines from the primer bulb to the carburetor on a poulan woodshark model 1950 chainsaw
The lines should be connected to push fuel into the carburetor. The output (overflow) of the carb is routed back into the tank. So, two lines in the tank, one is an overflow (return) and the other is the suction. On the primer one line from the tank and the other to the carb. Connect so as to "push" fuel into the carb when the primer bulb is pushed.
Jun 16, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Poulan chainsaw gas line routing?
There ARE two holes in the tank. One samll and another larger. One is on the left side and the other is on the right. Look carefully and you'll find them. As far as connections of the fuel lines:
The line from the fuel filter in the tank goes directly through the small hole in the tank to the top nipple on the carb thus giving the carb a constant supply of fuel when running. The primer bulb is used only for "priming" and does not play a part in the fuel flow after that function. The bottom nipple on then carb then goes back to the nipple on the primer bulb which is clearly marked "Carb". The above connections are made with the smaller diameter tubing. From the primer bulb, marked "Tank", the larger diameter tubing is routed to the large hole in the tank. The tubing goes into the tank only 1/2 to 3/4 inch. As far as getting the tubing through the holes in the tank, cutting the tubing at a slant. But no matter what you do it is still a witch. Be patient, use some Vaseline and avoid the temptation to get out the drill and **** the hole to a larger size.
Aug 30, 2009 | Garden
Poulan 2050 chainsaw. Fuel line routing. Replaced all fuel lines. Primer bulb is marked Tank and Carb side. Tank side is for larger line and runs into tank and fuel filter. Carb side is smaller diameter...
Replaced my fuel lines on poulan 2050 today. The large diameter line is a return line from the primer to the tank. The smaller diameter line is the supply line from the tank to the carb. You need to cut this line and run a second piece of small diameter line from the card to the primer. I'm not sure if it makes a difference which of the two stems on the carb is the inlet or outlet line. I used the top stem as the inlet, and connected the bottom stem to the primer. My chainsaw started right up. So I either got lucky or maybe it doesn't matter.
Apr 14, 2009 | Garden
Routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Mar 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My poulan wont start any suggestions
Plugged fuel line or carb due to sitting with fuel in tank. Drain tank and back flush line, changing filter if there is one. Inject some compressed air into fuel line from carb.jet screw hole, thus blowing out line toward tank. May have to also use some carb.cleaner in same area.
Prevention: Always shut off fuel line and run carb dry before storing unit. If storing a long time, remove all fuel as gasoline will not keep long, esp. in the carb.
Best wishes!
Feb 10, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Replacing a fuel line for a Poulan 2175 type 2 chainsaw
Take top cover off(3 screws). Take off the 2 nuts holding the carb on. Pull carb part way out to access the hoses. Remove the 3 old hoses after making a diagram of where they connect. Buy new hoses. Cut one end of the small hose on a bevel, pierce both sides 1/8 th inch from the end with a needle. Thread a thin wire through both holes. Thread both wire ends into the gas tank. Use a hemostat or long needle nose plyers to pull the wires and then hose down into the tank. Attach the weighted fuel filter. The other end of this smaller diameter fuel line goes on the upper nipple on the carb. Take the side cover off (4 screws) to access the primer bulb. Take 2 screws out to remove the bulb which has 2 nipples. The longer nipple connects to the larger diameter hose which goes to the fuel tank. The larger diameter tube has a coupler on the end which is inside the gas tank. It took me an hour to change all 3 hoses.
Bob
Jan 31, 2009 | Garden
Garden Logo
443 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
