Question about Refrigerators
Drain Hose Clogged
I have a Frigidaire Frost Proof Side-by-Side Refrigerator.  I have been informed by a technician that the drain hose is clogged.  How do I unclog it?  (We know we had a problem because we have water leaking from from the freezer from time to time.)  Will a simple defrost solve the problem?
    Problem Solver:
  • 18 Answers
Re: Drain Hose Clogged
You need to blow the drain line out with either air or the co2 cartridge kit made for blowing the drain lines out.
Posted on Oct 14, 2007
0 characters
3 Points
My gallery dishwasher doesnt drain all the way
Thank you for your inquiry, friend!
From my understanding your Frigidaire dishwasher doesn't drain properly. It could be possible that your drain line or filter trap is clogged. I would recommend checking the drain hose to make sure it is not clogged or kinked. You can also look at the filter in the bottom of your tub to access that filter you would need to remove the rack and it is located right under the spray arm. You should be able to lift up and pull the trap out if it is dirty clean it and reinstall it. If everything appears to work properly it could be a possible issue with your drain pump and you may need to have it replaced. I hope this information is helpful for you. -Matt
Feb 27, 2015 | Frigidaire Gallery Series GLHS269ZDB 36"...
How to get to the drain line on my Frigidaire side by side refrigerator model number MRS22WNGW7. Water keeps coming out of the freezer side onto the floor (front left side). I was told it could be a...
I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
May 14, 2010 | Refrigerators
Dishwasher won't drain
Check the following areas to combat this issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/control
Replace if defective (note: uncommon problem).
Jun 17, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water leaks down back of frig and pools under veg crisper
there is a drain hose that drains the frost from the freezer down to a drain in the botton of your refrigerator. then: to the evaporator tray under your refrigerator If the tube or, drain get clogged the water has no where to go and, pools in the refrigerator To fix this clean the hose with a coathanger or, stiff wire If you do not know where the hose is see the parts diagram for your refrigerator at:
May 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
The problem was indeed a clogged frost water drain. I had to pull the frig out from the wall (found an incredible amount of dust accummulation in the alcove), then remove the vertical metal and horizontal cardboard covers to expose the drain catchpan. The 1/2" rubber drain hose end was only about 1/8" above the pan pointing directly into it perpendicularly. This was not enough clearance. There was a plug (formed by dust and water) in the end of the hose that came out easily when I 'roto-rooted' it with a screwdriver. The water flowed easily after that, but I went ahead and trimmed about 3/8" off the end of the hose and pushed it back into its slot. Then I cleaned as much as I could. The prevention is to keep the area behind the frig cleaned!
Nov 07, 2008 | Refrigerators
Water Leaking
HI thanks for your question. the drain tube in the freezer is clogged, not allowing the defrost water to go down to the drain tray. to repair. turn fridge off , for 24 hrs. remove back panel from fridge clean all coils. locate the drain tube by the drain tray. use a small hose to shove up the drain tube And blow , to clear the debris from the drain tube. thanks the appliance doc. please rate my answer. thanks
Oct 14, 2008 | Frigidaire FRS26R4C Side by Side...
Ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Nov 28, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
475 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
