Question about Dishwashers
Dishwasher not getting dishes clean
I recently bought a second hand Kenmore Ultra WAsh 111 dishwasher. Upon running it on Pots and Pans mode, it went through the whole process but the dishes were still super dirty, the soap wasn't even gone and the inside of the dishwasher was YUK! Any ideas on what is wrong? Thanks!
  • kidslit-writ May 13, 2009
    Thanks so much - I'll see what I can do.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
That is why it is seccond hand. If it was a good one the first owner would have kept it.Probably the impeller at the pump is shot, Change the impeller. Vitally
Posted on May 13, 2009
Kenmore ultra wash model 15951793 sani wash flashing
what is your model number is then we can get started then
Jan 04, 2013 | Kenmore 24 in. 16032 Built-in Dishwasher
Tip
Tips For Dishwasher for its safety and getting dishes cleanest
A) If your household is small, try gradullay accumulating a full load of dishes and rinsing as you go, instead of stacking dirty dishes in the dishwasher.
B) Cleaners and some elbow grease will always get pots and pans cleaner then the pots and pans cycle on the dishwasher.
C) Good crystal and china should be hand washed and not placed in the dishwasher since the detergents and jostling can damage them quite easily.
D)It can take several hours for dishes to dry when using the no-heat dry option the dishwasher. Try propping the door open to speed the drying process.
on Dec 14, 2009 | Dishwashers
Tip
Thank God for smart people and information on the internet!!! We just moved into...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Oct 06, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a greasy buildup on my dishwasher filter.
It is the grease left on dishes or pots & pans. It can be cleaned off using a good regular dishwashing detergent like Dawn in the sink, not in the dishwasher. To prevent it, scrape the dishes & pots better, and if possible, turn the temperature of the hot water up a few degrees. You should also change dishwasher detergents to a liquid, with a built in water softener.
Sep 05, 2009 | Frigidaire Dishwashers
Pots and pans and normal wash blinking
Try resetting it. Locate the switch in your breaker box, and flip it off- then on again. Hope that works!
Aug 09, 2009 | Kenmore 13743 Staimless Steel Built-in...
White film/residue left on dishes
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. Dishwasher Magic is a good choice. works great.
Jun 18, 2009 | Kenmore Dishwashers
My detergent cover broke
yes u can run it just like that or vist sears.com for parts u need Here to Help Shaun
Nov 18, 2008 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Dirty glasses
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 29, 2007 | Tricity Bendix 24 in. BDW53 Free-standing...
Dishwashers Logo
136 people viewed this question
Top Dishwashers Experts
Owen Barnes
