Question about HP Pavilion a400n (DQ173A#ABA) PC Desktop
Blue button flashing
I have a hp pavilion n400 and had it in a garage for 6 years, dusted tried but it still has a problem the blue power button fashes when I plug it in?What do i do?
  • JDTec
    JDTec May 11, 2010
    Are the fans working:
    Do you hear the hard drive spin up?
    What was it doing way back before you put it in the garage?
  • HP Master
  • 2,404 Answers
The reason why the button is flashing is cause the power supply is not putting out the right voltages and the motherboard can't power on.
Best thing to do is to see if you can try a different known good power supply and hook up the connectors to the motherboard only and see if it turns.
This usually takes care of the problem. I have also seen it where the motheboard is bad on rare occasion. To verify the motherboard after trying a different power supply is to make sure there is no cards in the pci slot and makes sure none of the drives are connected and the only cables that should be connected to the motherboard is the power supply.
Hope this helps and let me know if you need extra help.
Posted on May 13, 2009
Hp pavilion blinking blue light
Press the power button to get it out of sleep mode.
Sleep mode, think of it as a power nap.
Jan 19, 2014 | HP Pavilion Desktop a6300f Intel Pentium...
HP Pavilion a1514n wont power on. Green light lite on back. Front power button flashes blue when pressed.
That blue flashing light may be a POST code. Does it flash continuously or does there seem to be a pattern to it?
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 02, 2011 | Computers & Internet
I have an HP Pavilion ze4200. It will not even
1. It looks like a battery problem!
2. Plug in your laptop to fully recharge the battery!
3. After 3-6 hours, try to start your system!
4. You can also check by changing the power jack / socket!
5. Is the battery light On / blinking ?
Jan 04, 2010 | HP Pavilion ze4220 Notebook
Won't Start
This happened to my to my HP Media center Edition PC. I'd have to unplug the power from the outlet, let it stop flashing and the power up again. It would run for a short time and then shut off with the annoying amber / blue flashing light.
I found it was a heat problem on mine - specifically, the CPU cooler. After shutting down and opening the PC, check to see 1) if the CPU fan is running smoothly and 2) if there is a lot of dust and dirt on the CPU cooling fan and heat sink (and rest of the case for that matter).
Gently clean / vacuum the insides of the case AND power supply as best you can. Carefully vac the fan blades and heat sink to clear the dirt and dust that prevents the heat from being blown away by the fans.
When complete, you might even want to take the PC outside and reverse the vacuum so that air can be blown into tight places in the case. A can og compressed air can do the job instead, too.
Reassemble and start up as normal. Good luck!
Sep 18, 2009 | HP Hewlett Packard Pavilion Slimline...
Compaq laptop will not power up
try taking the battery out, make sure the ac adaptor is not connected, hold down the power button for 60 secs and then put the battery back in and try turning it on.
Sep 14, 2009 | HP Pavilion dv6000z Notebook
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
HP pavilion will not shut down
pull the power cord out and the battery (or just let it run out). Then, try turning it back on again. If it does the same thing again then yes it may be old blue death and your harddrive may be worse than dead. I don't believe that the power button doesn't work. Hold it in for 10-15 seconds or so, any computer is DOS programmed to respond to the power commands above all, even above the dreaded blue screens. Let me know if I'm an ******* and I don't know what I'm talking about or if you need more help.
Mar 07, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion a400n (DQ173A#ABA) PC Desktop Logo
125 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
