Question about Epson Computers & Internet
New Epson TX101 cannot print from network
Just installed an Epson TX101 on the main PC (Replacing an HP Laserjet - which worked) it works fine on the main PC, it also installs (or so it looks like) on the secondary PC, yet when I try to ptint from any program I get the following message: ''The Parameter Is Incorrect'' and when I try to do a Test Print from the properties on the 2nd PC I get the message ''Test Page failed to print. Would you like to view the print troubleshooter for assistance? Operation could not be completed.''
There are no entries in the event logs at all. I have also recently installed the Epson TX101 printer replacing my old Epson Printer.I ahve the same problem - while the printer works on my laptop,I cannot print from my i Mac.I get the message "Client error not possible" when document is sent for printing,even though the initial message is "printer ready for printing"
A.T.Cariapa
'why i cannot cannot connect printer my network have some alitle bit computer that cannot connect and other can. I already check Computer Name, IP and WORKGROUP. but when i ping to computer that has printer it work. How should i do about this or this printer share only alittle.
Posted on Jul 18, 2009
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
My tx101 epson all-in-one printer-does not print just the black ink even with a new genuine epson black cartridge
Make sure you removed the top tab to let air in. Remove the cartridge and make sure the plastic on the bottom got punctured when you installed it,and the little piece of plastic isn't caught in the ink port.
If you still can't print, your printheads are probably clogged. remove the cartridge and clean the print heads with a Qtip and some isopropyl alcohol (windex also works).
Mar 06, 2011 | Office Equipment & Supplies
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Lost cd for laserjet 1320 cl6 printer. installed
either the usb wire is getting loose in the new laptop port.or the port is faulty.press the usb wire tightly and then try printing keeping it pressed at the laptop side and printer side too.with some bodies help. check out.
Jul 12, 2009 | HP LaserJet 1320 Printer
Laserjet 1320n Will not print
You need to install the 1320 driver on the "new" pc.
Mar 13, 2009 | HP LaserJet 1320 Printer
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
HP2550N PRINT QUEUE WON'T PRINT UNLESS TURNED OFF THEN ON
This definitely sounds like a driver problem so you will need to delete the old driver and then install the most current driver and patches from HP Support.
Also Go to C:\Windows\System32\spool\PRINTERS on your PC and you will see two files listed fior each of the outstanding print jobs. These will have the file extensions .SHD and .SPL
You need to delete both of these files then power off and power on your printer to be able to continue printing.
Oct 03, 2007 | HP LaserJet 2550n Printer
Printer offline
1) Ensure you've run the D-Link supplied automatic configuration wizard. 2) Also ensure you have "Netbios over TCP/IP" enabled in your network settings. 3)Ensure you turn off "Bidirectional Printing" in the Ports tab and "Enabled Advanced printing features" in the advanced tab, for testing purposes. I know the printer connectivity is officially supported by D-Link (thru an independent 3rd party test facility) but it seems they may have had NetBeui installed, which is an outdated networking protocol. Try the first 3 options I gave, if they don't work, then let me know. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Computers & Internet Logo
283 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
