Question about Samsung SGH-D600 Cellular Phone
Wet phone i recently dropped my phone in the bath, and now it switchs on but after 3 seconds it goes off please is there any way i can fix this problem without it costing me a fortune?????
I droped mine in a pond and i couldnt find it for a day and whn i did find it i took it apart and put it in my airing cupboard for a day n it works fine now
Posted on Nov 05, 2007
    Sergeant:
  • 452 Answers
Open ur entire phone put it in sun light, after two hrs try if it is not working then goo to service centre and they will flash it or definitely its hardware problem.
Posted on Oct 17, 2007
Had burst pipe, used geyser water to bath kid. Water supply now restored but geyser switch in box keeps on tripping... Help!
Use hair dryer and see if you can dry out parts.
Often, when electronics get wet, they cannot be repaired... like dropping cell phone in bucket of water.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 28, 2013 | Mountain Plumbing Water Heaters
Just got this phone yesterday! dropped in water... pulled out and shock water out and dryied it with a hair dryer..no moisture appears on screen. Dried battery...waited an hour and put on charger..the...
There may be some water logs present in the phone which obstructs the functioning of the phone.
Never switch on the wet mobile,When the power goes to the circuit board it may short circuit the full mobile motherboard.DONOT put your mobile in charge when it is wet it may be very dangerous.
You need to remove the water logs present in the mobile. So,please go to mobile service centre in your place and they will fix it.You cannot fix it yourself.
Thanx
Aug 07, 2010 | Cell Phones
My phone dropped in the bath!
you might have some water damage. take the phone to a repair centre
May 06, 2010 | Nokia E63 Cell Phone
My nokia 6303 dropped in water bath...its not working now .it is dried now
have u tried to start it when it was wet if not then keep it in sunlight for sometime & then after that try to switch it on if it doesn't start contact ur nearest mobile servicing center
Feb 21, 2010 | Nokia 6303 Cell Phone
I dropped my samsung E840 phone in the bath 2days ago and the screen went black but the phone still lit up...the screen is now back to normal but goes black every now and again and the numbered buttons are...
Recent phones dont agree with water to much, but what you can do is pull it apart and spray it all with a electric cleaner, but if you have insurance on your phone that would be the best way to replace it, warranty wont cover it. you could try to hard reset it but most likely wont work still
Sep 27, 2009 | Samsung SGH-E840 Smartphone
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Blue screen on main display
You most likely need a new ribbon cable, which is the cable that connects the two halves of the phone. They are not expensive and can be ordered on eBay, and they come with the tools required to disassemble the phone and replace the cable.
Jun 01, 2009 | Nokia 6085 Cellular Phone
Drop phone in bath
The only thing you can do is dry it out more with heat(hairdryer). Remove the battery while doing this. If you still have the same problem then yes, unfortunately the keypad has shorted out.
Please remember to rate this answer.
Feb 11, 2009 | LG Prada KE850 Cellular Phone
Phone is wet please help!!!
If it is not ruined you could leave it in a jar of dry rice. This should take care of the moisure.
Jan 18, 2009 | Motorola Mobility W490 Cellular Phone
Wet celphone
not really. It is time to get a replacement.
Jun 26, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Samsung SGH-D600 Cellular Phone Logo
20 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
