Back to:
Tags:
HP PSC 1510 All-In-One InkJet Printer
All copies and scanner outputs result in a totally...
posted by Belle Cooper on Oct 14, 2007
Regardless of color or black/ white copies or scans, the image output wheather on paper or electronic file is a totally black image,no text,no lines. The scanner ligth seems to be on and working. As a printer machine works fine.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 16, 2007
Thanks for Trying (70)
MUKHTAR
Rank:Wiz Wiz
Rating: 78%, 510 votes
i is problem with your scanner if you ablt to open it and just apply little bit servicecing for your scanner head rod or ypy can show it service peronnel.
bye
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on All copies and scanner outputs result in a totally black image:
I don't want to Accept this solution
Solution #2
posted on Oct 15, 2007
abdool
Rank:Apprentice Apprentice
Rating: 78%, 3 votes
I have been using this model of the hp printer and it has not really been problematic, if your warranty is still valid contact the HP Support office nearest to you ASAP for a replacement.
Thank You!
Solution #3
jackboy
Rank:Wiz Wiz
Rating: 77%, 3817 votes
CCD failure  would seem to be a possibility
I would thing a repair is not likely
A replacement machine a possibility if of recent purchase
Contact  HP customer support
Thank You!
Can you Help with these Printers problems?
Printer was working good.I shut down computer and turned...
When I scan a photo I get dark bars showing over the...
When using the Memorex Cd labes I can not get the labels...
The printer does not print black. The black area on the...
Was working fine.  we put in a new black cartridge....
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
