Question about Philips GOGEAR SA6045 MP3 Player
The screen say file system error then turn off
    President:
  • 2,923 Answers
This error message means that the system is corrupted. You need to bring it to the manufacturer for reprogram and for firmware upgrade.
Have a great day!
Posted on May 13, 2009
How to fix fatal error
In order to fix your phone, you need to be calm and patient. Make a wrong move and no one will be able to help you.
Method A) First thing to do is determine if you can connect your phone to your computericon1.png and open its file-system up. If you can, just replace the files that you messed up with the original files (If you didn't back-up get the files above) and then restart your phone.
Method B) If you cannot access your file-system because your phone is constantly rebooting, the first thing you need to do is turn your phone off. If the on/off button doesn't work, pull the battery out to turn it off (DON'T TURN IT ON). Then connect your phone to your computer (While its off, and it should turn on by itself and go into a charging screen) and see if you can access your phone's file-system, again if you can replace the messed up filesicon1.png, and restart your phone.
Method C) If you STILL can't access your phone file-system, don't fear there's still hope. Some users have reported success using this method, but it may or may not work for you. Try holding all 4 buttons (camera, lock/unlock, and volume rocker) on the side when the phone is starting, see if you can get it to a white screen with information stating "This phone has the IMEI. If you want to make the gang image erase the IMEI," if you see that, connecticon1.png your phone to your computer and replace the files, then restart.
Method D) If you find that you cannot stay in the gang image screen above, meaning it turns blue/black with error fatal when you connect to the phone, then do this: Remove the SIM card out and turn on the phone. Hopefully you will get the emergency call screen to display (where you can only make 911 calls). Connect to your phone now and replace the files.
__________________________________________________ _________________________________________________
I also got the fatal error screen and another way to get it to the gang image screen is to remove your sim card and leave the battery in then plug it into a wall charger and then use the four button thing to take it to the gang screen, after it gets there unplug it from the wall charger and plug it into the data cable and the screen will remain at the same position..
This is Basically a Factory Reset for your phone. Try the other solutionsicon1.png above, then go for this one. Kind of a..Last Resort i guess you could say.. This is also known as the "GrCobb Method"
I had the same type of problem and had trouble resolving it by putting back the files I thought I had changed. I was getting LG's 'blue screen of *****' with a message like Fatal Error: Dog: 1 or something like that. Here is what I did:
1. Downloadicon1.png the LG Vu firmware files from this site (http://www.lg-vu.com/index.php?topic=3902.0). Unzip it. These files contain the entire LGAPP firmware folder. Then unzip it. It should create a LGAPP directoryicon1.png with every file that was on your phone when you got it. I know DH said to not replace the entire LGAPP folder because it may brick your phone but, hey, it's already bricked so not a problem.
2. Get into EFS and connect with your phone. Get to the gang screen on your phone using the steps if you have to.
3. Rename the LGAPP folder to something else (LGAPP_bad). Do not delete it. There are some files that are read only and you get an error message replacing them when you copy the new GAPP on top of an existing LGAPP directory. This doesn't happen if you rename the old LGAPP to LGAPP_bad before you do the copy.
4. Copy the LGAPP directory you unzipped above to the phone and restart it.
That is what I did and it came back to a clean state as if you did a factory reset.
Hope that helps.
Jul 20, 2014 | LG Vu CU920 Cellular Phone
Tip
Blue Screen of Death
The stop error screen or bug check screen commonly called the blue screen of death (also known as a BSoD, bluescreen, or "blue screen of doom.
In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
Often, if you're lucky, the problem will resolve itself with a simple reboot and you may never have to worry about it again. More typically though, the BSOD is a harbinger of trouble and you may find yourself faced with another and another until you throw up your hands in frustration... but all is not lost.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This is if you are able to boot into safe mode (Press and hold the F8 key during boot up). This will ensure that all driver bugs are fixed and that all hardware has the correct driver. If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name. There is a neat program on the net that can fix this problem, it's called DriverFinder, you can get it here.
If this doesn't work or you can't think or find the corrupt driver you could use System Restore (If it is enabled) to go back to a time where you didn't get the error. To use the system restore utility, go to 'start/all programs/accessories/system tools/system restore.
Sometimes though the blue Screen of death can be caused by faulty or loose rame cards. Check that your RAM modules are inserted correctly and arn't clogged with dust.
After using the computer for a few months or years, the hard disk gets fragmented with temporary files, or fragmented files. This will result in slowness of the hard disk and may even result in a computer crash eventually. You can maintain your harddisk by defragmenting your hard disk and deleting unwanted files frequently.
If you see Fatal OE exceptions and VXD errors then it is due to the video card. To solve this reduce the video display resolution. You can do so by going to the control panel and display settings. Choose the correct screen resolution to match your monitor.
on Nov 14, 2010 | Computers & Internet
Philips gogear 8gb mp3 file system error
m8 that happens to minebut i cant fiqure it out
Oct 22, 2011 | Philips GOGEAR SA6045 MP3 Player
File system error
Push in the tiny reset button on the device. If that doesn't fix it, install the latest firmware from Philips.com
Sep 10, 2009 | Philips GoGear HDD1830 MP3 Player
Archos 400 won't turn on (error code 3)
I hard tried the same thing to transfer a 6.7GB file to another computer.I had formated the drive as an NTFS drive. when i turned archos back on, it failed to turn on give me error code. but for some reason it asked me to do a recovery. I remember i had seen some recovery files in my archos device saved (zipped file packages). And when it was doing the recovery i noticed it was reading the zipped files for recovery purpose. After the recovery, i did not see the files anymore in the device. So if i do the same thing again (format as ntfs) i might not be able to recover it back again.
Mar 11, 2009 | Archos 404 Digital Media Player
Desktop goes black/blank after opening
Can you go to safemode and check if you are able to see the icons.
Did you run a virus scan lately. If not you can try that.
Let me know the results and i can guide you further.
Feb 16, 2009 | Dell Inspiron 1501 Notebook
File system error
If its possible plug the unit in your computer and it should come up in My computer under removable storage. Right click it then cilck format.
Jan 05, 2009 | Philips GoGear SA3245/37 Digital Media...
Blue Screen
Use the following steps to replace the missing files when Windows cannot start.
  1. Turn the computer on and place the first recovery disc into the top drive.
  2. After inserting the disc, turn the computer off, wait about ten seconds, and turn the computer on again.
  3. If an HP Recovery screen displays "Press any key to continue...", press the spacebar.
  4. To continue, read the warning screen and click OK.
  5. Click Advanced Options at the top of the screen.
  6. Click Selective Recovery.
  7. Read the Select Files to Restore window that appears.
  8. Type the name of the file. For example, if the error message is MNYUTIL.DLL is linked to missing export MFC42.DLL, type MFC*.DLL.
  9. Click OK. If there is more than one recovery disc, it may be necessary to insert another disc when prompted.
  10. When therecovery process has finished copying files, remove the disc andrestart the computer. If problems, persist it may be necessary toperform a system restore or a non-destructive recovery.
(Note: Click here for information on ordering the recovery CD/DVD sets)
thx.
Oct 08, 2008 | HP Computers & Internet
It says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error?? It says File system error when I turn it on and then it turns itself
it says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error??
Nov 26, 2007 | Creative Labs MuVo V200 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
162 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
