Question about Brother IntelliFax-2820 Laser Fax
Brother MFC-7220 says close back cover but it's already closed
    President:
  • 405 Answers
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Posted on Mar 30, 2010
    Problem Solver:
  • 11 Answers
1.Just check if you closed well your cover
2.Or check the sensor of cover may be is covered by paper or dust
Posted on Dec 31, 2012
2 Suggested Answers
memturbo
  • 226 Answers
SOURCE: Brother MFC-7220 says "close back cover" but it's closed
Have you tried this solution by joefishny:
Turn the machine around so that you are facing the back. Open the back cover. Pull down the second
smaller roller cover inside the machine. If you look closely at the second smaller cover, on the right hand side (closer the the inside of the machine), is a very thin round piece of plastic that is only half the
length of the smaller cover. There are 2 thin plastic tabs attached to either end of this round piece of
plastic. Gently shift this over so that the 2 plastic tabs can now go into the space provided for them. I had to move mine over only 1/4 inch.
Posted on Mar 28, 2009
Brother MFC 7220 message indicates "Close back cover". Cover is closed. Nothing seems to eliminate the problem.
Inside the back cover there is a black "rod" this is the rear sensor actuator. It should be straight with its peg fitting inside a slot on the rear cover area (and should also have a small spring on it)
Mar 01, 2011 | Brother MFC-7220 All-In-One Laser Printer
How do i reset the drum counter on the mfc 7220
Welcome to FixYa
Dear User
Open your Front Cover
In Control Panel Press Options.
You can See -Replace Drum -Yes/ No
You have to Press 1 to Reset it.Then you can Close the Cover.
Hope you did it....Thanks for Connecting FixYa..
Sep 06, 2010 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC-7220, paper coming out like a Fan. All creased or not coming out at all and jamming at the back. Any ideas....
your fuser has gon bad or something is blocking the paper path. Open the back and look close for any objects. If nothing there you need a new fuser. Steven 805-520-3003
Jul 08, 2010 | Brother MFC-7220 All-In-One Laser Printer
MFC-7220 All-In-One Laser Printer: the back cover open message will not go away...
There is a paper jam in the machine which is blocking the sensor for the back cover.
Remoev the drum and toner (cartridge) from printer and look inside, there should be a piece of paper there, you need to remove it slowly
May 16, 2010 | Brother MFC-7220 All-In-One Laser Printer
It says close back cover but back cover is already closed
Apr 19, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 8840D still says change drum soon
press clear/back button
press 1 and when the lcd shows accepted, close the front cover.
thanks adi
Apr 27, 2009 | Brother MFC 8840D All-In-One Laser Printer
Mar 28, 2009 | Brother IntelliFax-2820 Laser Fax
I have a Brother MFC-7220 USB printer. It keeps telling me that the back cover is open ... and it is closed. Now I cannot use it. lease help. Thanks.
hte back cover has a little micro switch.
open the back cover, make sure there is nothing preventing from closing tight. close the back cover tight. if you have to, use tape to secure it.
Feb 11, 2009 | Brother Office Equipment & Supplies
Mfc-7220 Back Cover Open
This one made me crazy, but I finally figured it out. Turn the machine around so that you are facing the back. Open the back cover. Pull down the second smaller roller cover inside the machine. If you look closely at the second smaller cover, on the right hand side (closer the the inside of the machine), is a very thin round piece of plastic that is only half the length of the smaller cover. There are 2 thin plastic tabs attached to either end of this round piece of plastic. Gently shift this over so that the 2 plastic tabs can now go into the space provided for them. I had to move mine over only 1/4 inch.
Jan 03, 2008 | Brother MFC-7220 All-In-One Laser Printer
Brother IntelliFax-2820 Laser Fax Logo
470 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
