My screen is stretched with a 1 and ahalf inch black space on the top and bottom
My screen is stretched and has a 1.5 inch black space on the top and the bottom of the screen. I owned this monitor for about 2 months and had no problem until now
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    What operating system are you running?
  • 221 Answers
Most LCD monitors have a couple of control buttons at the top or on the side. Inside the menu, there should be an option called "Auto Adjust" which senses the input signal and resolution, and then shifts the monitor to match it. Have you tried to auto-adjust the screen? There may even be a button called "Auto" on the monitor.
Posted on May 13, 2009
How to fix horizontal lines across screen and black bar at bottom?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent. Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Oct 22, 2015 | Sony SLV-695HF VCR
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Need to stretch screen to fill space on monitor
Here is a good tutorial on how to adjust the screen resolution on a mac: How to change Mac screen resolution Macworld . However, it may be that the output from your computer doesn't match the size of the screen you have. Did you check to see that the computer can output an image that matches the size of your screen. That is a common problem.
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Mar 04, 2014 | DoubleSight DS2700DW Monitor
I run on Windows XP, pack3 and I use a CRT ViewSonic EF70 ... 17 inches The screen is not filled completely with the image from Microsoft Internet Explorer, nor with Outlook Express .... there is about 3...
two things you can do, first right click on your windows screen and look for "settings" this will open a dialog box where you can set the screen resolution. Set it lower and see if your screen is now filled. if that doesn't work go into the monitor setup (buttons on the bottom or side of the monitor) and try to set the verticle and horizontal size, since its only 3/4 of an inch you should be able to stretch the screen to fill up the space.
Mar 11, 2011 | ViewSonic E70f 17" CRT Monitor
My proview 558 monitor has a 1/2 inch black line at the bottom
ms_biguns, You need to test one or the other, The tower should output and drive a substitute known good monitor, or a known good pc should be able to display the WIN-desktop screen on your Proview 558. Could it also be that the software in pc not set up for driving a Proview558? 12fixlouie
Feb 28, 2010 | Proview Computers & Internet
There are 2 inches of black space on both sides of my screen.
There should be a way to go into the screen settings on the set (either from the remote or on the bottom of the screen). From that menu you can adjust the size of the screen, stretch it, align it, etc.
May 04, 2009 | Emprex LM2201 22" LCD Monitor
My rca d52w19 52 inch shoots a 2 inch flame from the back,WTF
You are talking about the screen/focus block it is bad sometimes they just split open call UED for replacement part 1-800-836-4920 or go to www.ued.com
Dec 05, 2008 | RCA D52W19 52" Rear Projection Television
Display is off-center
Try the Auto adjust button on the monitor buttons first.
If the entire picture of the computer is showing you can try to shift and stretch the picture through the menu button.
Sep 04, 2008 | E-Machines eMachines Monitor E15T4
Vertical section problem
I have found an fix for this a capacitor 2494 needs to replaced.
Aug 21, 2008 | Philips 27MT3305 27" TV
My scren is not showing my info bar on the bottom and there is a one and a hlf inch black line on the right of my screen and ahalf ince black line on the upper portions of my screen and my screen itself if...
You can adjust your display through 1 of two ways.
1. Somewhere on your monitor are buttons that allow you to adjust your screen position, ( left- right-up-down, widen / stretch in both direction, up & down at the same time & left & right at the same time. If you still have the manual for the monitor it will explain how to do this. Every monitor is not the same & each monitor has their own way to adjust monitor positions.
2. This might be a bit harder but all you'll need is youe mouse.
Find an emty space on your desktop, ( yeah I know it's messed up right now, did I mention this would be harder?).
I want you to right click once on your desktop & that will open a small pop-up menue. Left click once on Properties
You have just opened your display Properties. ( I need to mention just like the monitor adjustment screen is different from one to another, your video card will also be different.) My instructions should be close for you to adjust your screen.
So you have Display Properties on your screen. Click the settings tab, than click the Advanced button. Here click the Adapter tab. Look down & you'll see a button ( List All Modes).
Click it. The mode screen will open. There is a scroll bar on the right. Slide the scroll bar down & pick out the setting you want.
Most people use setting - 1024 by 768, True Color (32bit), 60 Hertz
Click Ok & than Apply. Your screen should adjust it's self.
If it does not, than someone messed with the monitor adjustments & you'll have to re-adjust from the monitor.
Mar 10, 2008 | Computers & Internet
Computers & Internet Logo
610 people viewed this question
David Payne
David Payne
