Question about Nokia 5310 Cellular Phone
Dropped phone screen stopped working
Everything works except for LCD screen when turned off then on backlight comes on but screen remains black I am looking for a retailer in Australia
    President:
  • 625 Answers
If the screen on your 5310 is deador the backlight is not working, you can buy a replacement 5310 LCD andreplace it yourself. A new Nokia 5310 display Screen costs about 20 dollars fromebay. I wrote a detailed guide to help you put in the new Nokia 5310 screen. Check it out at the following link:
Nokia 5310 LCD Screen Replacement
Hope that helps
Posted on Aug 21, 2009
I have had that same problem. 2 words. NEW PHONE
Posted on May 13, 2009
Olympus 850 sw digital camera 2 yrs old! Used all day perfectly fine turned back on screen blank, still takes photos, Still flashes, still beeps when press buttons just lcd screen is black likes its off?...
Hi
Either the LCD screen is cracked or defective in some other manner. It's possible the LCD works but just the backlight is out as well. Either way, the camera needs to be opened and the LCD checked out.
The Olympus "Tough" and "SW" cameras are FAR FROM being either "Tough" or "S"hock and "W"aterproof. I have seen dozens and dozens of them with cracked glass over the LCD and destroyed by water damage. Sounds like something got inside your camera or it was badly dropped.
Hope this helps.
Thomas Drayton
Owner, Darntoothysam.com
Affordable Digital Camera Repair
Sep 07, 2011 | Olympus ? 850 SW Digital Camera
HTC Touch Pro LCD Going black and then sometimes working
is there the "calendar" and "contacts" menu buttons on the bottom of the black screen?
that's what would happen to me. i just turned off the touchFLO 3D on the today screen (by going to settings, then today screen options) and it seems to not go black anymore... even after being untouched for hours.
not sure if the same thing is happening to you, but it worked for me.
Jul 19, 2009 | HTC Touch Pro Smartphone
Samsung u600 screen now blank
if can go in setting and go to black light click it and hit turn off
Jul 07, 2009 | Samsung SGH-U600 Cellular Phone
Sony ericsson W580 cell phone
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank or it the LCD connector may have come loose.
A new LCD screen runs about 15 dollars shipped from ebay.
The W580i LCD is easy, easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony W580i LCD Screen Replacement
I hope that helps you out
Jun 10, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Sidekick III 3 LCD Backlight stopped working sometimes
yes you need to replaced the LCD to make it work again.
Jun 03, 2009 | T-Mobile Sidekick® 3 Cellular Phone
DISPLAY NOT WORKING
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
May 05, 2009 | Sony W880i Cellular Phone
LCD screen is black
Hi
If you look really closely at the screen can you see an image? You say you can see if you point the camera at bright light... Sounds like your backlight is either damaged or just unplugged.
If you are comfortable doing the repair, you need to open up the camera and remove the front and back case. Check the small ribbon cable under the LCD, is it damaged or unplugged? Try taking it out and plugging it back in, now does it work?
Keep the camera away from static shock, and only turn the camera on with the front and rear body on, never off.
If you need somebody to do the repair for you, we are an affordable digital camera repair business (Google: darntoothysam) and we can definitely take care of it for you.
Good luck from Darntoothysam com
Thomas
Oct 16, 2008 | Canon PowerShot SD600 Digital Camera
My screen is black. Can you help me?
I had a similar problem, but in my case teh screen was not entirely black but the image was very dar, like someone shut of teh lcd backlight, but the photos were coming ok (when checked on the pc). Showed it at repair sho, abd found out that one of the pcb supplying power to the backlight was not working and had to be replace. couldn't do much at home.
Apr 03, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
17" LCD Monitor - only works for a few seconds when turned on.
It seems to be an Inverter related problem in which backlight seems to be shiutting down.Is this monitor 3-4 years old???If so backlight of the panel could be an issue.
Feb 15, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
Nokia 5310 Cellular Phone Logo
269 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
