Question about Numark iDJ2 - DJ iPOD Mixer Docking Station
Wont load all songs
Im using an ipod and the numark librarian to build the library for the idj2. I have about 1000 songs on the ipod. when i open the librarian to create a new library it only imports 371 of the 1000+ files. WHY? any help would be appreciated. thanks.
    President:
  • 1,197 Answers
The version of numark library that u use might be a problem... it is likely that it treats files as broken and doesnt read them at all.....  Improved detection and rejection of invalid files such as Apple Lossless files within an M4A container. These will not be imported into the library.
This occurs when you:
* Drag music from another location into iTunes.
* Addmusic to iTunes using "Add to library..." ("Add file to library..." and"Add folder to library..." on Windows) from the File menu in iTunes.
Or you may see a message reading:
"Error occurred while converting the file 'song name'. You do not have enough access privileges for this operation."
This can occur when you:
* Import music from an audio CD.
* Convert a song iniTunes to another file format using "Convert Selection to chosenformat" from the Advanced menu in iTunes.
"There was an error downloading your purchased music. iTunes couldnot save to your Music Folder because you do not have write access.Check the permissions on your Music Folder, then use the Check forPurchased Music command in the Advanced menu to try again"
Resolution
These messages occur if permissions are incorrect on your designatedmusic folder or on a folder inside your designated music folder.Permissions are settings that determine who can read, write to, orexecute a file or folder on your computer. Every file and folder onyour hard disk has an associated set of permissions.
Note: Permissions and privileges for files are different fromauthorization to play a song purchased from the iTunes Store. Clickhere for information on authorizing a purchased song to play.
and here are the instruction i can find for fixing permissions (said for xp but vista might work this way to) http://support.microsoft.com/kb/308419/en-us
if ur using Mac OS
some of the individual band's folders within the library have a padlock symbol.
When u look at them with Get Info there is a message "You can onlyread" immediately above the area where it says I have "Read &Write" privileges.
to unlock them
1. Using Finder, the top level folder of those files that you want to unlock. Switch to List View mode (cmd-2).
2. You should now see a finder pane containing only those files and folders that you want to unlock.
3. Cmd-a to Select All.
4. Open all the sub-folders. With all selected, opt-command-right arrow to open up alllll the children.
5. Cmd-A to select all
6. Opt-Cmd-I to bring up the single pane inspect
7. Unlock
also ensure u have all the read write permissions for the folders clik the following link
http://support.apple.com/kb/HT2963?viewlocale=en_US
if ur not using the computer..... please follow the below procedure....
Rebuild your iTunes library to make sure the XML file is intact and clean. You can find the directions for that here.
Plug in iPid and use the updater to completely restore your iPod to it's factory settings.
i recommend u to reinstall numark library again... try downloading the firmware update for version 1.09 a
i wud however recommend trying podutil... thats the best....
hope that was of help...
thank you have a nice day good luck with ur ipod
Posted on May 13, 2009
I pod touch 4th gen. wont work with numark librarian on idj 2
will iPod touch 4th generation work for idj2? Can you mix and scratch with it?
Mar 30, 2011 | Numark iDJ2 - DJ iPOD Mixer Docking...
I want delete songs from idj2 pls help
There are no songs on the IDJ2
Only on your Harddrive / USb stick or Ipod.
If you want to play songs via the IDJ2, you need the librarian software for using the IDJ2 in combination with you songs.
Dec 02, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
The button to send songs to deck 1 wont work help me plz
My button to send songs to deck B won't work either. Anyone know how to remedy this? I upgraded to newest firmware, Im successfully running librarian and no other problems. That 2nd function button does not work, however. This is the button that sends tracks to deck B, it also is the pull deck B button, and the cancel button. So I am dead in the water without this button working. I just bought the unit from someone and it was only used once, still in the box,etc. HELP PLS!
Jan 14, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
The system wont load all of my songs. I used the library tool and it loaded 800 out of my 1000 songs
some songs are protected files and wont load. i know dude, i cant play 15% of my library. very frustrating. apple made no friends on that one.
Dec 26, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Idj2 librarian hangs
chances are you will have a corrupt file in there somewhere. i had the same problem when it stops it will show what song it is stuck in the progress bar if you no wat i mean? delete that song and start again
Jun 15, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Still asks me to download librian
The idj2 doesn;t search off your ipod. you have to put libraries together with the librarian tool.
Here is a manual for your idj2 it's clear and will tell you how to import a library to your computer for search and play.
send me your email and I will send you a manual i downloaded steveb661@yahoo.com
May 18, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Library questions
Librarian 1.50 / IDj2 fimware 1.09
Read the other Q & A's, about IDJ2
Regards,
Jack
Jan 29, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
When docking it takes too long transfering data from ipod to idj2
if you have a PC, you're better of preparing a library for your USB/IPOD devices with Librarian 1.50, but only if you are running 1.09(a) firmware on the IDJ2. This is the preferred and quicker way...
Do an upgrade if this is not done yet. Go to
http://www.numark.com/contentmgr/showdetails.php/id/1230/tt/5
for downloading the files.
When rerunning the librarian(for instance when adding tracks), choose normal mode. It will add every playable track. (you could try this out on an USB stick with some tracks on it for testing purposes).
If this doesn't work, you could have a corrupt library, and have to rebuild(choose advanced in Librarian). Also, when you have created with earlier versions of IDJ2 firmware, then you have to rebuild the whole library.
Numark stated on their forums, when connecting a device, to never choose update, but load instead. It can use mp3/wav/non secured aac files, but not wma..
If there are any other questions, you can also send an e-mail to numark. They are reasonably quick with their responses.
regards
Jack
Dec 26, 2008 | Numark iDJ2 - DJ iPOD Mixer Docking...
When i connect ipod to idj2 it still shows up old library...
I have the same problem. But it's easy to fix. You must connect your ipod to a pc and then you must go to My computer>(select your ipod and open the folder) and then delete the folder -   .Library   - It's done!
Dec 25, 2008 | Numark iDJ2 - DJ iPOD Mixer Docking...
My IDJ2 is unstable
not sure what it can be, but if you used librarian before, be sure that you are running librarian 1.50 with fw 1.09(a). If you have created a library with 1,33, then you have to create the library again with the 1.50 version. Don't use USB powered drives. Mostly they overload the USB port, with al sorts of weird problems. If you have one of these, use an USB powered hub to remove the load of the IDJ2 port. You could test with an USB stick, for a few hours..
regards,
Jack.
Dec 23, 2008 | Numark iDJ2 - DJ iPOD Mixer Docking...
Numark iDJ2 - DJ iPOD Mixer Docking Station  Logo
75 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
