Question about Cuisinart DCC-1200 Coffee Maker
Cuisinart coffeemaker doesn't work
Ok, I paid 99.00 for this, thinking it would never fail me. You know the old saying "you get what you pay for". I tried the little piece on the bottom and the unit is still not working. I'll keep on taking suggestions, otherwise a nasty letter and my money back will do the trick. kkatthebeach.
  • 85 Answers
Hello kkatthebeach,
I recently had this similar problem. If you still have you machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
I have a cup o matic and it has recently started leaking from the main unit...???? Can I fix it?
you can if you can find where the leak is, and as long as it is just a worn o-ring and not a crack. You could contact Cuisinart for service? There are some articles on your particular problem in the main link at the bottom.
Pt 1: How To Use: Cuisinart SS-1 Cup-O-Matic Coffee Maker - YouTube
? 10:04
https://www.youtube.com/watch?v=jEPf5hXWkB4
Oct 18, 2007 - Uploaded by Jay Brewer
Learn how to use coffee pods and ground coffee with the Cuisinart SS-1 Cup-O-Matic Coffee Maker.
SS-1 - Coffee Makers - Discontinued - Cuisinart.com
https://www.cuisinart.com/discontinued/coffee_makers/ss-1/ Regular or bold, large or small - your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffeemaker, it's easy to brew your cup ...
[PDF]Cup-O-Matic™ Coffeemaker SS-1 - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/ss-1.pdf Cup-O-Matic™ Coffeemaker. SS-1. For your safety and continued enjoyment of this product, always read the instruction book carefully before using.
Amazon.com: Customer reviews: Cuisinart SS-1 Cup-O-Matic Single ...
https://www.amazon.com/Cuisinart-SS-1-Matic-Coffeemaker.../B000RIAIXO Find helpful customer reviews and review ratings for Cuisinart SS-1 Cup-O-Matic Single Serve Coffeemaker, Black and Brushed Chrome at Amazon.com.
Cuisinart® Cup-O-Matic™ Single Serve Coffee Maker - Bed Bath ...
www.bedbathandbeyond.ca/store/product/cuisinart-reg-cup-o-matic.../1014760199 Regular or bold, large or small, your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffee Maker, it's easy to brew your cup ...
Cuisinart Cup-O-Matic Single Serve Coffeemaker Review
www.goodhousekeeping.com/.../cuisinart-cup-o-matic-single-serve-coffeemaker-881/ Rating: 2 - ‎1 review
Unlike coffeemakers that only make a cup at a time, this model can be used with your favorite ground coffee as well as from coffee pods.
Single Serve Coffee Forums
cup matic leaking water Google Search
Sep 03, 2017 | Coffee Makers & Espresso Machines
Cuisinart troubleshooting
My Cuisinart 12 cup thermal coffee maker does everything but make coffee. I put water in the back and it just stays there. I turned it on pushed on start, clock works, and probably 2 minutes later the red light comes on and says it's done. But water is still in the reservoir. Could the hose be affected? or is there a pump? Would like to know as the coffeemaker was expensive. Now about 4 yrs old.
Jan 03, 2014 | Coffee Makers & Espresso Machines
Coffeemaker shuts off in the auto brew cycle
Your Cuisinart coffee maker probably is defective, though new.
Jan 10, 2018 | Cuisinart Chw-12 Coffee Plus 12-cup...
I HAVE A CUISINART DCC-790 SERIES COFFEEMAKER AND IT WON'T PUMP THE WATER THROUGH
I have the same problem. Called Cuisinart and they told me to add a mix of 50 - 50 water vinegar and let it sit for up to 3 hours. (even though it is only 3 months old) If that does not work call them back 1-800-726-0190.
Feb 13, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart COD 4000 coffeemaker
Just a comment; most of the coffee maker failures are caused by the premature failure of a thermal fuse that is intended to prevent fire in case the main heater doesn't turn off as it should. Unfortunately, most of these parts come from China and are very poorly made so the point at which they 'protect' is pretty unpredictable, many of them failing at a much lower temperature than necessary. The second most common failure is the thermal switch that cycles the main heater element; these are bimetallic switches that grow 'tired' and the point at which they open and close again gets wider apart until it can take an hour for a 12-cup pot to finish brewing.
Jul 15, 2009 | Cuisinart Coffeemakers
Our Cuisinart DCC 2000 is dead after only 6 months. I would like to get a replacement from the manufacturer. How do we prove the coffeemaker is under warranty still?
This model has a VERY WELL-KNOWN and wide-spread design flaw. The condensation runs down the back and destroys the micro-computer that runs the works. Cuisinart has been less that forth-coming and just replaces with another, equally boadly designed, replica that then, gee, what a surprise! - also fails in about 9 to 12 months.
Great idea but a BAD design and a less than responsible manufacturer.
Maybe if they caught fire like the old Mr Coffee's then the manufacturer would step up to the plate and solve the problem rather than hoping that their customers just get tired of having to fight.
Jul 07, 2009 | Cuisinart DCC-2000
My almost 2 yrs old Cuisinart DCC 2000 coffee maker just stop working suddenly. The pre-set time was melfunction on every Sunday for about a month before it went dead completely now. There is a 3 yrs...
Try this and let me know if it works - plug the coffeemaker in, turn the function knob to BREW, and then press all 3 buttons in the center of the coffeemaker (the 1-4 button, et, etc) and hold them for a few seconds. Let me know if the clock display comes back on.
If not, call Cuisinart and see if it is in-warranty by serial number 1-800-726-0190.
Jun 23, 2009 | Cuisinart DCC-2000
Works sporadically
May 09, 2009 | Cuisinart DCC-2000
Set up for 12 cups. Starts ok but stops after
Unplug the coffeemaker for 20 minutes OR LONGER (not a second less). While it is unplugged, fill the water reservoir with 1/2 caraffe distilled white vinegar and 1/2 caraffe water. At the end of the twenty minutes, replug the coffeemaker and brew the vinegar/water just like it was coffee. You may have to run it through up to 3 times. If the vinegar/water cleaning fails to restore the coffeemaker to normal, you have a deeper issue. This product has a 3-year warranty, so call Cuisinart if you are within your 3 years.
-Tha Mp3 Doctor
Mar 22, 2009 | Cuisinart DCC-1000 Coffee Maker
Self Clean Button
Unplug the coffeemaker for 1 hour or longer - it should reset the coffee maker and get rid of that self-clean light.
-Tha Mp3 doctor
Jan 24, 2009 | Cuisinart Coffeemakers
Cuisinart DCC-1200 Coffee Maker Logo
945 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
