Question about Gateway 2520915 Keyboard
Gateway keyboard types wrong characters
I have a Gateway system that came with a KB-0532 keyboard, version T, that is driving me insane.
Some of the keys have alternate characters, appearing in blue. For example, the quotation mark/apostrophe key alternates to a pair of 'slanted' apostrophes; the pipe/backslash key alternates to angled brackets.
This could be handy, however, the keyboard will, every few moments, arbitrarily start using these alternate characters. I can temporarily solve the problem by quitting the application and restarting it. When I'm working on a web project, and have several windows open in Dreamweaver, it's a serious inconvenience. I have searched high and low for a solution to this problem but cannot even find a reference to it. The computer came without any keyboard-related documentation, nor can I find any on the Gateway website.
I've tried to reinstall the driver, looked for new drivers, and even reinstalled the OS. Nothing works. I'm desperate for any advice you can offer, and am grateful in advance.
  • 4 more comments
  • bananapatch Oct 14, 2007
    I should add that this problem can occur in any application, and while it is happening in one application, I can switch to another application, or open a new one, and the keyboard will work fine for a few moments.
  • bananapatch Nov 12, 2007
    Thank you...that was one of the first things I checked.
  • cpthook Dec 03, 2007
    I have tried to change it by using the Shift Alt key combination but it just makes it upper or lower case. First off, how does one go about activating the Blue characters, knowing that might help me in turning it off. Sorry but i'm a real dummy at this.. Any help would be great, right? So why would the question mark now work here? I've met my frustration level!
  • Annother Jan 04, 2008
    I have the same problem. It only happens when I'm writing emails in Thunderbird. None of the proposed solutions works for me.
  • bananapatch Feb 11, 2008
    kjag, I could not ever possibly thank you enough. Thank you!!! You CANNOT imagine the frustration this has caused me.
    THANK YOU!!!
    Cheers,
    Darrell in Toronto (Bananapatch)
  • Anonymous Nov 07, 2008
    yes, it's happening to me as well and it's driving me nuts. If someone knows how to fix this problem, could you please teach us.
Same keyboard, same problem for almost 2 years now, and just now figured out how to fix it!! Try a simple left ctrl-shift, your language tab up top will switch between US English/Canadian English/Canadian multilingual, or whatever you set it for. I occasionally want the alternate characters applied, so now I can switch back and forth easily. You may need to set the language tab to your preferred settings. Hope this helps!
Posted on Feb 05, 2008
  • Aida Garay
    Aida Garay Mar 29, 2014
    kjag - you are the best!!!!!!!!! This was driving me nuts!!!!!!!!!!!!!!!
Thank you all. I ultimately found that next to EN on the lower task bar is something that looks like a steam train but is actually an icon for the keyboard! When I clicked on it I found that there were three choices: US, Canadian Multilingual Standard, and English (Canada). When I checked "US" the problem went away. However, this is an unsatisfactory solution for someone writing in Canadian Standard English.
Posted on Jan 15, 2008
    Scholar:
  • 121 Answers
Might there be a key marked "Fn" or something like that nearby the shift, ctrl or ALT keys that you might accidentally touch? I have only seen such alternate symbols on laptops usually, and they are often a "numpad". Look for a "Fn" or "F Lock" or something similar and see if that will toggle it on or off.
Posted on Nov 07, 2007
  • Christian Ramsvik Nov 13, 2007
    Sorry, I forgot to log in before I posted the followup.
Sounds strange. Is it only "special characters" that are behaving strangely? Are all the letters still OK?
Do you have a little blue box with the letters "EN" on it in the taskbar? It soundslike you may be changing keyboard layout. This can be done by hotkeys (I think it's ALT+SHIFT to toggle) or by clicking the blue box with EN (assuming you have english keyboard layout) Try pressing ALT+SHIFT and see if this changes things. If so, that's your problem.
I use Norwegian keyboard layout myself, but windows by default installs english support, and it's fairly easy to change this by accident. You can remove the problem entirely by going to START->Control Panes -> Regional settings and remove the keyboard layouts you don't want.
Posted on Nov 13, 2007
    New Friend:
Old thread, but just want to add that none of these solutions will work for some people. I think a majority of users don't realize that how many languages appear on the language bar, how to switch between them using hotkeys, and whether the language bar even appears at all, are ALL user configurable. I have exactly one language defined-US English-because I removed any others. I don't have the language bar (or a keyboard icon, or anything pertaining to this subject) appearing on my taskbar, because I have no need for it. And for the same reason, I disabled any hotkey activity pertaining to language, since for one thing I use dozens of hotkeys I've defined to do other things, they all use different combinations of the Ctrl, Shift, and Alt keys, and if I didn't disengage language hotkeys they would just get in the way. -BUT-... despite all of the above, I too was using the exact same Gateway keyboard, and I too had *lots* of very weird problems with it when I tried using it on a different computer. In the end I simply junked it since I had others I could use, and never really found a solution, but I can confirm that none of the replies in this thread, well-meaning though they undoubtedly were, would solve my problems with that keyboard.
Posted on Feb 18, 2015
    New Friend:
Keyboard language problem using shift keys (getting blue letters)
-On taskbark, click keyboard icon...
  • RightClick turn off AUTOADJUST
  • LeftClick change to US language
Posted on Sep 18, 2013
The Fn key (bottom-left) invokes the second function of keys that have a second function (in blue).
The Fn function can be locked on or off by holding the Fn key and pressing the Padlock key.
Padlock is the second function of the Scroll key (near top-right)
Posted on Mar 19, 2008
  • reddogllc Feb 09, 2011
    I had the same problem with my key board and I tried this little trick and it worked like a charm. Thank you.
  • Txpita Jan 10, 2013
    I LOVE YOU....quick easy fix for my son's borrowed laptop....thank you soooo much.
Thank you, the Alt Shift seems to have worked, I don't have the Fn or EN keys on my board.
Best regards from Cpthook.
Occasionally a glitch will occur where a certain symbol will keep repeating itself as if I'm holding the key down. Such as \\\\\\\\\\\\\\\\\\\\\\. I
Nope, the KB isn't completely clean - you have a key that is staying stuck down - (usually some dirt in it. Work out which keys - showly working through each of them - then pop the top off that key, and clean under it. Or get a Replacement KB.
Nov 14, 2013 | Gateway kb-0532 116-key ps/2 french...
Print Screen button will not print to printer
use programs like paint to capture print screen then print from there
Jul 20, 2013 | Computers & Internet
I have a gateway keyboard KB-0532 it will not work can i download new drivers for it
You could try to find "new" drivers for download, but you are NOT likely to find any, *AND* any new drivers are NOT likely to solve your problem.
Try your keyboard in a different computer. If it still fails to work, it's necessary to replace the keyboard. If it works, try connecting that other keyboard to your computer.]
If that "other" keyboard works fine in the "other" computer, but does NOT work in your computer, then your keyboard is NOT the cause of the problem; instead, your computer has some other problem.
May 21, 2011 | Gateway 2520915 Keyboard
Gateway wireless keyboard model KR-0532 Serial-7L236B0294B and I have windows vista home premium 32 bit is there any way to know when caps lock are on or off? thank you.
there is no indicator light , so other than trial by typing and looking to see id the only resolution. some wireless combo devices will actually popup a screen indicating that your cap locks are on.
Nov 28, 2010 | Gateway 2520915 Keyboard
Partial keyboard doesn't work.
Try blowing on it with canned air or a hair dryer. Other than that keyboards are cheap and easy to replace. Good luck!
Mar 13, 2009 | Computers & Internet
Keyboard driver
gateway.com has a driver page with the drivers for everything they've ever pumped out
Feb 12, 2009 | Gateway 2520915 Keyboard
Keyboard does not work
there is a problem on your keyboard hub ,, or the CPU hub,, check the hub, try it to another keyboard, if it wil work therefore your keyboard has defect
I mistakenly reprogrammed my gateway keyboard
If you are on Vista (Maybe XP has it too), go to the Classic View in the Control panel/Default Programs. At the bottom click on "Set Program Access and Computer Defaults" From there, follow your nose back to the one you want--down carrets open some choices. My KB-0532 was set to "custom" and then it let me chose my browser, mail program, etc.
Dec 18, 2008 | Gateway 2520915 Keyboard
Helpp!
Have you tried installing the keyboard software? If you have, try reinstalling it and see what happens..
Mar 31, 2008 | Gateway 2520915 Keyboard
Gateway 2520915 Keyboard Logo
9,934 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
